    Blend, artefact when changing gradient shape
    34 Posts 3 Posters 51.3k Views 3 Watching
    • B Offline
      B-Vs-V
      I was just playing with the blend tool and it was fine until I changed the shape of the gradient. I got then many weird artefacts.!
        Subpath @B-Vs-V
        @PatrickM
        i mentioned already a Gradient Prob
        with Gradient Mesh Editor.
        It looks somewhat similar
        Here the Link
        • B Offline
          B-Vs-V @Subpath
          @Subpath Ha ok, thanks for the link.
            VectorStyler @B-Vs-V
            @PatrickM Yes, this is probably related to the mesh gradient rendering issue with GPU.If the Preferences -> Performance -> Compute Engine is set to Software, it should render correctly.
            Are these gradients along the stroke, or just regular gradient fills?
            • B Offline
              B-Vs-V @VectorStyler
              @VectorStyler It is set to 'Software'. Issues with 'along' and 'across'.
              • B Offline
                @VectorStyler when I duplicated a blended form (alt + click & drag) and press 'shift' to keep the duplicated form horizontally, the blend(ing) disappeared.
                Edit: the history panel is empty
                  @PatrickM I tried to replicate this, with a basic blend case, but seems to be working here.
                  If you press Command+R (Refresh) does the blend reappear?
                  And is the blend in a group or just the 3 objects (source / blend / target)?
                  • B Offline
                    @VectorStyler It happens when you release Alt (sometimes Shift) while still pressing the left mouse button
                    • B Offline
                      @VectorStyler I've sent you the file after the issue occurred by email ☺
                        @PatrickM Got it!
                        • B Offline
                          @VectorStyler I was "playing" with blending, stroke shape etc. Why do I get only a few dashed blended strokes/lines when I select "dash" in the stroke panel ? see below:
                            @PatrickM I think the dash attribute is not blending correctly. I think this might be a bug.
                            • B Offline
                              @VectorStyler modifying some features of the blended scheme such as the thickness of the stroke considerably slowed down VS and finally, VS did not respond and crashed the PC.
                                Subpath @B-Vs-V
                                @PatrickM
                                no problem here
                                even with a gaussian blur effect
                                  @PatrickM said in Blend, artefact when changing gradient shape:
                                  The gradient artifacts should be solved now.
                                  This slowdown might be caused by something else. If you have a file, where I can change the stroke thickness to replicate this issue, please send it to me.
                                  • B Offline
                                    @VectorStyler I was only using VS when the issue occurred.
                                    I think it is more the "dash" feature that is an issue because I did change this many times for the two strokes and I did get many dashed lines. Every time I did zoom in and out, all the lines/strokes were blurry for seconds before they get sharp.
                                    I did modify the thickness afterwards and VS was not responding until I got the famous app blue circle for minutes and then suddenly I got my start windows screen.
                                    It might be related to VS & my graphic cards (too much calculation for my old graphic card ?) because then when I wanted to use Photoshop, an alert inform me that it could only use the cpu.
                                    I did properly restart the pc and it was fine then (VS not tested). I've sent you the file ☺
                                    Thanks
                                    Patrick
                                    • B Offline
                                      @VectorStyler I can open old adobe files but I don't get what I did.
                                      I did this years ago in Adobe Illustrator :
                                      When I open the file in VS:
                                        @PatrickM Got the file, will try to replicate it.
                                          @PatrickM I would need the AI file to replicate this issue. The problem occurs when importing the effects from AI.
                                          B 3 Replies Last reply Reply Quote 0
                                          • B Offline
                                            @VectorStyler I've sent you the Illustrator file.
                                            Thanks,
                                            Patrick
