    Blend, artefact when changing gradient shape
    34 Posts 3 Posters 51.3k Views 3 Watching
    • B Offline
      B-Vs-V @VectorStyler
      @VectorStyler It is set to 'Software'. Issues with 'along' and 'across'.
      • B Offline
        @VectorStyler when I duplicated a blended form (alt + click & drag) and press 'shift' to keep the duplicated form horizontally, the blend(ing) disappeared.
        Edit: the history panel is empty
          VectorStyler @B-Vs-V
          @PatrickM I tried to replicate this, with a basic blend case, but seems to be working here.
          If you press Command+R (Refresh) does the blend reappear?
          And is the blend in a group or just the 3 objects (source / blend / target)?
          • B Offline
            @VectorStyler It happens when you release Alt (sometimes Shift) while still pressing the left mouse button
            • B Offline
              @VectorStyler I've sent you the file after the issue occurred by email ☺
                @PatrickM Got it!
                • B Offline
                  @VectorStyler I was "playing" with blending, stroke shape etc. Why do I get only a few dashed blended strokes/lines when I select "dash" in the stroke panel ? see below:
                    @PatrickM I think the dash attribute is not blending correctly. I think this might be a bug.
                    • B Offline
                      @VectorStyler modifying some features of the blended scheme such as the thickness of the stroke considerably slowed down VS and finally, VS did not respond and crashed the PC.
                        Subpath @B-Vs-V
                        @PatrickM
                        no problem here
                        even with a gaussian blur effect
                          @PatrickM said in Blend, artefact when changing gradient shape:
                          The gradient artifacts should be solved now.
                          This slowdown might be caused by something else. If you have a file, where I can change the stroke thickness to replicate this issue, please send it to me.
                          • B Offline
                            @VectorStyler I was only using VS when the issue occurred.
                            I think it is more the "dash" feature that is an issue because I did change this many times for the two strokes and I did get many dashed lines. Every time I did zoom in and out, all the lines/strokes were blurry for seconds before they get sharp.
                            I did modify the thickness afterwards and VS was not responding until I got the famous app blue circle for minutes and then suddenly I got my start windows screen.
                            It might be related to VS & my graphic cards (too much calculation for my old graphic card ?) because then when I wanted to use Photoshop, an alert inform me that it could only use the cpu.
                            I did properly restart the pc and it was fine then (VS not tested). I've sent you the file ☺
                            Thanks
                            Patrick
                            • B Offline
                              @VectorStyler I can open old adobe files but I don't get what I did.
                              I did this years ago in Adobe Illustrator :
                              When I open the file in VS:
                                @PatrickM Got the file, will try to replicate it.
                                  @PatrickM I would need the AI file to replicate this issue. The problem occurs when importing the effects from AI.
                                  B 3 Replies Last reply Reply Quote 0
                                  • B Offline
                                    @VectorStyler I've sent you the Illustrator file.
                                    Thanks,
                                    Patrick
                                    • B Offline
                                      @VectorStyler ... the right file this time 👍
                                      • B Offline
                                        @VectorStyler very strange: the file looks fine with W10 (gtx1070) but it's chaos with W11 (gtx3080).
                                        W10
                                        W11
                                          @PatrickM In Windows 11, select Software mode n Preferences -> Performance.
                                          EDIT: Is w11 with the Intel GPU?
                                          • B Offline
                                            @VectorStyler "Software" is already selected.
                                            I might have an intel gpu on the mother board but I don't know whether it is used. How can I know ?
                                            Thanks.
