    Blend, artefact when changing gradient shape
    34 Posts 3 Posters 51.3k Views 3 Watching
      Subpath @B-Vs-V
      @PatrickM
      i mentioned already a Gradient Prob
      with Gradient Mesh Editor.
      It looks somewhat similar
      Here the Link
      • B Offline
        B-Vs-V @Subpath
        @Subpath Ha ok, thanks for the link.
          VectorStyler @B-Vs-V
          @PatrickM Yes, this is probably related to the mesh gradient rendering issue with GPU.If the Preferences -> Performance -> Compute Engine is set to Software, it should render correctly.
          Are these gradients along the stroke, or just regular gradient fills?
          • B Offline
            B-Vs-V @VectorStyler
            @VectorStyler It is set to 'Software'. Issues with 'along' and 'across'.
            • B Offline
              @VectorStyler when I duplicated a blended form (alt + click & drag) and press 'shift' to keep the duplicated form horizontally, the blend(ing) disappeared.
              Edit: the history panel is empty
                @PatrickM I tried to replicate this, with a basic blend case, but seems to be working here.
                If you press Command+R (Refresh) does the blend reappear?
                And is the blend in a group or just the 3 objects (source / blend / target)?
                • B Offline
                  @VectorStyler It happens when you release Alt (sometimes Shift) while still pressing the left mouse button
                  • B Offline
                    @VectorStyler I've sent you the file after the issue occurred by email ☺
                      @PatrickM Got it!
                      • B Offline
                        @VectorStyler I was "playing" with blending, stroke shape etc. Why do I get only a few dashed blended strokes/lines when I select "dash" in the stroke panel ? see below:
                          @PatrickM I think the dash attribute is not blending correctly. I think this might be a bug.
                          • B Offline
                            @VectorStyler modifying some features of the blended scheme such as the thickness of the stroke considerably slowed down VS and finally, VS did not respond and crashed the PC.
                              Subpath @B-Vs-V
                              @PatrickM
                              no problem here
                              even with a gaussian blur effect
                                @PatrickM said in Blend, artefact when changing gradient shape:
                                The gradient artifacts should be solved now.
                                This slowdown might be caused by something else. If you have a file, where I can change the stroke thickness to replicate this issue, please send it to me.
                                • B Offline
                                  @VectorStyler I was only using VS when the issue occurred.
                                  I think it is more the "dash" feature that is an issue because I did change this many times for the two strokes and I did get many dashed lines. Every time I did zoom in and out, all the lines/strokes were blurry for seconds before they get sharp.
                                  I did modify the thickness afterwards and VS was not responding until I got the famous app blue circle for minutes and then suddenly I got my start windows screen.
                                  It might be related to VS & my graphic cards (too much calculation for my old graphic card ?) because then when I wanted to use Photoshop, an alert inform me that it could only use the cpu.
                                  I did properly restart the pc and it was fine then (VS not tested). I've sent you the file ☺
                                  Thanks
                                  Patrick
                                  • B Offline
                                    @VectorStyler I can open old adobe files but I don't get what I did.
                                    I did this years ago in Adobe Illustrator :
                                    When I open the file in VS:
                                      @PatrickM Got the file, will try to replicate it.
                                        @PatrickM I would need the AI file to replicate this issue. The problem occurs when importing the effects from AI.
                                        B 3 Replies Last reply Reply Quote 0
                                        • B Offline
                                          @VectorStyler I've sent you the Illustrator file.
                                          Thanks,
                                          Patrick
                                          • B Offline
                                            @VectorStyler ... the right file this time 👍
