    update 1.1.082
    17 Posts 4 Posters 1.9k Views 3 Watching
      @VectorStyler I'm having the same situation as @Igull but I'm not sure I swapped around any modified keys in the past.
        @Boldline I think only a Settings Reset might tell if the modifier keys were changed.
          @VectorStyler I reset both the settings and the workspace to defaults and using the control key is not constraining a shape's rotation in any way. Shift modifier is working. Is there something more than needs to be turned on or off?
            @Boldline The Control key thing works only when also holding the Shift key, and it should constrain the rotation relative to the current rotation of the object.
            • IgullI Offline
              Igull @VectorStyler
              @VectorStyler said in update 1.1.082:
              I tried a prefs reset with the same result. I don't need to use the control key, the shift key now rotates relative to the object's current angle, it doesn't force it to 0/90 as before. It seems that the relative rotate has been permanently installed ?
              Neil
                b77 @Igull
                @Igull
                When 'Relative Angle Constrain' is enabled in Prefs > Editing Options 1, only Shift is needed,
                and pressing Ctrl-Shift rotates in 45° increments ignoring the current rotation.
                When 'Relative Angle Constrain' is disabled, pressing Ctrl-Shift rotates in 45° increments + the
                current angle (say, 12°).
                • IgullI Offline
                  Igull @b77
                  @b77 said in update 1.1.082:
                  @Igull
                  Nope, just tried it again, always the same whether relative angle constrain is checked or not 😞
                  It always constrains relative to the current angle and never pulls the object back to 0 deg (or 45/90).
                  I did check that I was on 082 just to make sure 🙂
                  Any thoughts, I'm guessing another pref conflict ?? (although I did do a reset ).
                  Neil
                  • IgullI Offline
                    Igull @Igull
                    @Igull
                    I have also just tried it on Windoze 10 on my Mac using Parallels - same results.
                    Neil
                      VectorStyler @Igull
                      @Igull I will try to replicate this issue with the angle constrain
                      • IgullI Offline
                        Igull @VectorStyler
                        Neil
                          b77 @Igull
                          @Igull Maybe the object is "rotated" inside the bounding box, which will make it look like rotating it with Ctrl-Shift doesn't work?
                          • IgullI Offline
                            Igull @b77
                            Ahhh, this might be the case, well done. I hadn't even considered that it was relative to the bounding box and NOT the actual vector itself - doh 😞
                            My test was simply a bunch of lines created at odd angles - naturally, all those lines would have orthogonal bounding boxes 🙂
                            I had (stupidly ???) assumed that VS would know if a vector was orthogonal or not and would rotate it accordingly.
                            That's what I based my results on and obviously, that's not what the intended operation should be 🙂
                            Understandably, if one of my test lines were some complex object, then VS wouldn't know if it were orthogonal or not.
                            In that case, you would have to do a collision detect of some part of the object to say an orthogonal guideline to ensure orthogonality, then you would be good to go.
                            Thanks for that !
                            Neil
