    update 1.1.082
    17 Posts 4 Posters 1.9k Views 3 Watching
      @VectorStyler I reset both the settings and the workspace to defaults and using the control key is not constraining a shape's rotation in any way. Shift modifier is working. Is there something more than needs to be turned on or off?
        @Boldline The Control key thing works only when also holding the Shift key, and it should constrain the rotation relative to the current rotation of the object.
        • IgullI Offline
          Igull @VectorStyler
          @VectorStyler said in update 1.1.082:
          I tried a prefs reset with the same result. I don't need to use the control key, the shift key now rotates relative to the object's current angle, it doesn't force it to 0/90 as before. It seems that the relative rotate has been permanently installed ?
          Neil
            b77 @Igull
            @Igull
            When 'Relative Angle Constrain' is enabled in Prefs > Editing Options 1, only Shift is needed,
            and pressing Ctrl-Shift rotates in 45° increments ignoring the current rotation.
            When 'Relative Angle Constrain' is disabled, pressing Ctrl-Shift rotates in 45° increments + the
            current angle (say, 12°).
            • IgullI Offline
              Igull @b77
              @b77 said in update 1.1.082:
              @Igull
              Nope, just tried it again, always the same whether relative angle constrain is checked or not 😞
              It always constrains relative to the current angle and never pulls the object back to 0 deg (or 45/90).
              I did check that I was on 082 just to make sure 🙂
              Any thoughts, I'm guessing another pref conflict ?? (although I did do a reset ).
              Neil
              • IgullI Offline
                Igull @Igull
                @Igull
                I have also just tried it on Windoze 10 on my Mac using Parallels - same results.
                Neil
                  VectorStyler @Igull
                  @Igull I will try to replicate this issue with the angle constrain
                  • IgullI Offline
                    Igull @VectorStyler
                    Neil
                      b77 @Igull
                      @Igull Maybe the object is "rotated" inside the bounding box, which will make it look like rotating it with Ctrl-Shift doesn't work?
                      • IgullI Offline
                        Igull @b77
                        Ahhh, this might be the case, well done. I hadn't even considered that it was relative to the bounding box and NOT the actual vector itself - doh 😞
                        My test was simply a bunch of lines created at odd angles - naturally, all those lines would have orthogonal bounding boxes 🙂
                        I had (stupidly ???) assumed that VS would know if a vector was orthogonal or not and would rotate it accordingly.
                        That's what I based my results on and obviously, that's not what the intended operation should be 🙂
                        Understandably, if one of my test lines were some complex object, then VS wouldn't know if it were orthogonal or not.
                        In that case, you would have to do a collision detect of some part of the object to say an orthogonal guideline to ensure orthogonality, then you would be good to go.
                        Thanks for that !
                        Neil
