    Flickering canvas on M1
    20 Posts 4 Posters 20.1k Views
    • K Offline
      Kyriakos
      @vectoradmin Just reporting that i can still reproduce this issue - irregardless of the above setting - while using the Contour tool.
        fde101 Global Moderator
        Just to make sure you are aware, Apple has been investigating reports of issues like this with the M1 Mini as it seems to happen across various applications:
        https://piunikaweb.com/2021/01/08/apple-investigating-mac-mini-m1-external-display-flickering-issue-on-dark-backgrounds-no-release-date-for-fix/
        https://discussions.apple.com/thread/252106534
        https://us.forums.blizzard.com/en/wow/t/m1-display-flicker-issue-on-m1-macs-internal-and-external-displays/724003
        Thus this might not be a VectorStyler issue but rather something Apple needs to fix.
          VectorStyler @fde101
          @fde101 Thanks for letting us know!
          • K Offline
            Kyriakos
            There are indeed several power and sync problems with the latest display driver which can cause monitors to crash and i've reported a few myself, but the artefacts in VS are visible in screenshots and recordings and only inside the canvas, this is (positive) indicator than it's not as severe of a problem.
              VectorStyler @Kyriakos
              @Kyriakos Could not replicate this issue yet, will keep it open.
              • K Offline
                Kyriakos @VectorStyler
                @vectoradmin it seems to be fixed for all other tools except the Contour tool and i've narrowed it down to the 'Metal' document display mode. It also feels smoother and faster when set to 'Software'.
                  @Kyriakos Thanks for the info. I keep the issue open. This should not happen with Metal, and Software mode being faster is also strange (but maybe on M1 Apple made it faster with Metal).
                  • K Offline
                    @vectoradmin this might be relevant, VS exhibits the same flickering when you resize the document window.
                    https://thume.ca/2019/06/19/glitchless-metal-window-resizing/
                      @Kyriakos Thanks, I will try if it can be improved based on those comments. I do use MTKView when displaying with Metal, and on Intel Macs using Software display (basically just showing an image) is too slow.
                      • K Offline
                        @vectoradmin it feels slower when it's jittering, when it's not everything is extremely smooth and responsive.
                        I am trying Software mode right now and the only perceivable difference for me so far is document resizing which feels quite laggy. Drawing shapes however feels as smooth as Metal, i am not perceiving any major difference.
                        • encartE Online
                          encart
                          I saw these glitches on my laptop with Win10 also. But now I can't reproduce them. They appeard when I was rotating objects.
                            @Kyriakos @encart Can the flickering issue be replicated? There is a double buffering enabled for all display types now.
