    Bezigon Tool
    68 Posts 7 Posters 10.0k Views 7 Watching
    • DanielD Offline
      Daniel @VectorStyler
      @VectorStyler: No, The sequence produces the correct result. The reason is simple: The first click is modified twice. Once when it was place and the second time when when it was closed. And node 2 and node 4 are both sharp nodes, hence the top node becomes a cusp node with the handles of both pointing at the chord.
      If all the nodes are smooth, including the closing click, the top node still is cusp and the handles are still on the chord to node 2 and 4. This is because node 1 was modified twice, once when placed and once when closed.
      Consider this: The first node is placed as a square node, but all the others are modifier clicked. It still correctly produces a cusp at the top. The segment between node 1 and 2 on the left is approximated to a circle, as it should be. The segment between 1 and 4 on the right is cusped, and the handle points at node 4, the chord to node 4.
      • DanielD Offline
        Daniel
        @vectorstyler: I discussed it with Taras, my colleague. I think you should hold on the implementation of Tangent node. He agrees with me that it is just a matter of introducing a single new flag for each of the existing nodes rather than introducing a whole new node type. It is far more elegant, far simpler. Meanwhile, you can just work on getting the two main node types right. Sharp (&Cusp) and Smooth (&Symmetric).
        • L Offline
          larsherold @Daniel
          @Daniel said in Bezigon Tool:
          This might be far simpler than introducing a third node type. What do you think folks? @larsherold?
          It makes sense, as I guess the FH tangent Connector point can be viewed as a special case of a Cusp or Smooth Node.
          But the Connector Node is only useful/sensible as a tangent constraint if the neighbouring segment is straight. So when you "lock the handle of a smooth node e.g. to the chord" to enforce tangency, you will have to decide which handle to lock and staighten up the segment by retracting the handle downstream. (Or lock the downstream handle to the chord as well.)
          Actually the FH Connector node has two handles as well. The hidden handle can be extracted by Alt-dragging from the triangular node.
          Only, the second handle direction is locked, and seems arbitrary, like it has an undefined value when hidden.
          The FH Connector node can be forced to expose its second handle when placing it, resulting in a sort of direction-frozen Cusp node.
          Use the FH Bezigon tool to place 3 nodes: 1 smooth, 1 connector, 1smooth:
          The middle point is a Connector node alright, but not much tangency going on.
          The "stray" outgoing handle can be retracted, and the Connector node behaves like a tangent node again...
          BR/ Lars Herold
          DanielD 1 Reply Last reply Reply Quote 2
          • DanielD Offline
            Daniel @larsherold
            @larsherold: Yes, all of these can be reproduced with a simple flag for each of the two types of nodes. Including the two handled connector node. Thankfully, because we have mapped out every single rule, writing it back into the simple two node scheme is easy. Thank you for confirming this!
            Technically, and ideally, a tangent node is only every useful if it follows one direction. We can force this in the tool setting, but I'd rather not. FreeHand allows you the choice to have both handles available which you can manually collapse. I prefer that freedom.
            L 1 Reply Last reply Reply Quote 2
            • L Offline
              larsherold @Daniel
              You are right, the direction of the second (rarely seen) Connector handle is not arbitrary at all. Both visible Connector handles lie on the chord extension towards each neighbour node! Makes sense. You can retract either, and depending on what segment is (made) straight, you have tangency in one direction or the other.. 🙂
              There would have to be some visible indication that a handle is locked to a chord, and a means of unlocking it, I guess.
              DanielD 2 Replies Last reply Reply Quote 2
              • DanielD Offline
                Daniel
                @vectorstyler
                So the ideal way to proceed with this so that we can test it one step at a time is this:
                --> Fix bezigon rules for smooth and cusp as it currently exists in VS.
                --> Introduce flags for tangent nodes so that the handle is locked to chord and aligns to the chords of neighbouring nodes. --> Release --> Test --> Fix.
                --> Introduce true circle option from TikZ Lib --> Release -->Test --> Fix.
                --> Introduce handle clamps from Blender --> Release --> Test --> Fix
                You get this right, you'll have outright the single best pen tool option in the market.
                • DanielD Offline
                  Daniel @larsherold
                  @larsherold: Yup, figuring this out has been notoriously difficult. It is right under your nose and extremely simple once you see it. So is the 0.39 X Segment = Handle Length. Already worked out by several others. But putting these two pieces together has taken so long. More intelligent people would have seen it right away.
                  • DanielD Offline
                    Daniel @larsherold
                    @larsherold: Yes. We can simply turn it into a triangle! Just like in FreeHand. Except it's just a locked node!
