    Forum bug?
    12 Posts 6 Posters 5.9k Views 4 Watching
    • W Offline
      William Kansepa
      I don't know if anyone else is experiencing this, but each time I open forum posts, the last one takes forever to load. Say you have a total of three new posts, the first two will open normally but the last one will only open after a very long wait...
      S syllieS 2 Replies Last reply Reply Quote 3
      • S Online
        Subpath @William Kansepa
        @William-Kansepa
        Very rarely. This is usually a fast-paced forum. Sometimes
        marking unread posts as read takes a while. But that's all.
        On the other hand, I often experience long loading times in the
        BlenderArtist forum.
        M 1 Reply Last reply Reply Quote 1
        • M Offline
          monsterfox @Subpath
          @Subpath I thought only Chinese users would be like this. When I saw that you are the same, I instantly felt much better.
          • syllieS Offline
            syllie @William Kansepa
            @William-Kansepa I have exactly the same issue. And it does not matter in what order I read the posts. Just from the 'unread' posts view, whatever is the last remaining post takes a long time to open for reading.
            Windows 10 Pro | 22H2
            syllieS 1 Reply Last reply Reply Quote 1
            • syllieS Offline
              syllie @syllie
              Quick demo https://go.screenpal.com/watch/cT1tnfnXW3p
              • S Online
                Subpath
                @syllie , @William-Kansepa , @monsterfox , @VectorStyler
                Here a video from me
                about my loading times. Have no Problem even with a big Thread.
                Pictures may take a little while but thats all.
                  VectorStyler @syllie
                  @syllie said in Forum bug?:
                  This seems quite bad. I will try to find out what causes this.
                  • S Online
                    Subpath
                    In my experience with other forums, only two
                    of them have long loading times.
                    And the loading times vary depending on
                    what time I access a website there.
                    syllieS 1 Reply Last reply Reply Quote 0
                    • syllieS Offline
                      syllie @Subpath
                      @Subpath Hi Subpath - I think you misunderstood the context. The forum is really fast for all posts and in general no complaints at all (at any time). However if there is a select list (in my explicit case the unread posts), if I go through them one by one they all load fast, until I have exactly one left, and opening that one is super slow (as per video) and it is reproducible. Like in your video, you have 4 posts unread. Read 3 and then let the last one load.
                      @VectorStyler I should have added my browser info as that may be of influence too - I use vivaldi (chromium based) on windows 10.
                      And it is reproducible in Firefox too: https://go.screenpal.com/watch/cT1tjsnlclD
                      S 1 Reply Last reply Reply Quote 3
                      • S Online
                        Subpath @syllie
                        @syllie
                        aha, ok
                        will keep an eye at this then
                        • debraspicherD Offline
                          debraspicher
                          I have had this problem on and off.
                          32GB RAM @ 6000MHz
                          PNY NVIDIA RTX 5070 Ti 16GB; Display 1: 4K @150%; Display 2: 4K @150%
                          • S Online
                            Subpath
                            Okay, I've been keeping an eye on that.
                            It only appears for the last thread in the list of unread posts.
                            To my surprise, it also appears when I open the topics in the
                            list in a new tab.
                            So the last tab with the last topic in the list took a while to load.
                            I don't know exactly. But I'd guess it was 15-20 seconds. All the
                            others loaded instantly. I was using Firefox.
