• “Caching mechanism”。
    @monsterfox said in “Caching mechanism”。: The file is too large to be uploaded. I will send it to your email. @monsterfox - I use a free service called "Wetransfer" to upload larger files cannot be uploaded to the forum. I also use it when I have a lot of files to send or if i don't want to take up space in my email storage to do so. It gives the option to send an email or create a link you can copy and paste. I prefer the second option They have paid plans but the free one works well for me. You do have to sign up for an account.
  • Is Grouping broken ?
    @VectorStyler Yes double click for isolation is working.
  • Gradient tool adding stroke and affecting that instead of main fill
    @Boldline This could be caused by selection in the Appearance panel.
  • Color panel discrepancies - which to believe?
    @Raaskot said in Color panel discrepancies - which to believe?: What does "Default" then? "Global RGB" means "Default RGB"
  • Clones Always Have Fixed Center?
    The example I gave that showed it working was from Affinity Designer. I used symbols. There was no need to convert the rectangle to curves. Although Affinity Designer is my main app, I'm trying to use VectorStyler more since VectorStyler has more tools, some of which I find quite useful. For example, I like how VectorStyler has "center text on baseline." Affinity Designer doesn't have that tool, so I have to manually align the text. But VectorStyler is a lot more complex, so there has been a bit of a learning curve.
  • Loading Custom Brushes
    @JuurGroove said in Loading Custom Brushes: are the brushes made for Illustrator the best option in terms of compatibility with VectorStyler? Yes. But only vector brushes are supported (Photoshop brushes are not supported). An AI file containing vector brushes can also be opened with the Panels -> Presets -> Open Brush Preset File command to open the file content into a brush preset panel.
  • VS don't export overlays with blend modes correctly
    @VectorStyler Ok, I found a workaround without having to flatten the output. sampled all the colors created by the blend mode saved the swatches to the Palette panel reversed the foreground object (stroke) and background removed any blend modes applied saved colors directly to the stroke and background Would be great if the program could do this for me, but perhaps it's not so easy. Just an idea for future.
    @Boldline said in Why is black listed in the list of active colors in "replace color" panel?: Or to have a setting that limits the scope of color results to the individual artboard, all artboards, the canvas, or the full document? From my vantage point, this would be a powerful way to dial in what the scope of the listing would be
  • Dividing shapes with paths
    @Devil-Dinosaur Nice tip! Also, using the divide boolean will work as well
  • Path editing and errors
    17k Views
    @monsterfox said in Path editing and errors: It is not known whether this is the problem that causes the path offset error Yes, it is an offset "approximation" error for thin outlines (improved at larger zoom). Also: for the offset path effect, there is a Precision field, that can be reduced (there is always a compromise between precision and number of nodes added).
  • Node snapping
    Z
    @VectorStyler said in Node snapping: @Zero This will be in the next build. Awesome! Thank you.
  • Missing loaded and displayed Color Palettes in the Colorize function
    @Subpath Fix for this will be in the next build: palettes that are opened will show up in the list regardless of the folder.
  • Tiled windows keyboard shortcuts on macOS Sequoia
    @JuurGroove said in Tiled windows keyboard shortcuts on macOS Sequoia: but presumably because of the lack of Window menu in VS, the tiling keyboard shortcuts do not get triggered at all. Yes, the problem is that MacOS has a bit strange way of handling certain shortcuts. If n action is not in the menu as they expect (with the standard action assigned to it), then it is not handled. This creates problem with apps that allow menu customizations and don;t directly use those macos actions.
  • Character tool - Pivot point
    Z
    Thank you so much!
  • Unwelcome behavior in user color palette
    @Subpath yes, editing in an external palette is saved immediately. I will try to improve these.
  • Problem with Unsolicited Save popups
    @Boldline said in Problem with Unsolicited Save popups: "automatic save" save in the background Yes, it saves in the background. Please send me (by email) the workspace / settings files of VS, I will try to replicate this error
  • Is there a kind of pattern selection possible in VS ?
    @VectorStyler I already wrote that it was just a question, so there is no need to rush. If it is a useful addition to the selection options, then gladly. In the meantime, I think i already have a workaround as is possible in VS using the Colorize function with a 2-colored or n-colored palette.
  • Offset Path Issues
    TeddyT
    @VectorStyler Thank you!
  • Origin Location
    TeddyT
    @Subpath Thank you very much!!!
  • Renaming slices
    @VectorStyler After the latest update the mouse works. Thank you.
