• Scale Stroke
    @FastVector The Transform panel should have this in the 1.2 beta (click on the title up/down arrow knob). [image: 1703709499099-screenshot-2023-12-27-at-22.37.53.png]
  • Why do imported brushes open in new tabs in Brush Preset panel?
    @Boldline said in Why do imported brushes open in new tabs in Brush Preset panel?: added to the list in the existing main brush preset panel These brushes can be drag&dropped into the main brush set after opening them. Or: with a brush folder selected, select the Append command from the Brush presets panel menu and select the AI file to import brushes from.
  • Making Brushes Organization more Intuitive
    @Boldline You need to enable' Group Folders' from the panel's menu / Display for that. Should this be enabled by default?
  • Merry Christmas
    6 Votes
  • About 3D
    @Yaoif Not yet.
  • Docking Panel resize
    @Kumr Seems to be a bug. I will try to fix this for the next build.
  • [Help wanted] Invalid License Info
    I
    Huge thanks to you all! VS and its community are quite helpful and amazing. As I'm aboard, I will keep exploring it and supporting it by giving feedback when needed. Have a good day guys!
  • Arrange Objects In A Grid
    @FastVector , gladly
    @VectorStyler said in VS asks me if I want to save unused/untouched files before closing the file out.: @Boldline I will try to replicate this. This is what I have activated on the standard document creation: [image: 1701779463302-6d1424f1-0791-4d32-88b9-9fec1cf1379c-bld-2023-12-05-at-07.29.53.png] This is what I have my applicable settings set to: [image: 1701779527463-0a58e9e0-e22c-4894-846b-e0a8f46c3594-bld-2023-12-05-at-07.31.42-resized.png]
  • Can't change the tooltip delay
    I can now change the tooltip in the betรก version since the the new release from 1.2.006.
  • Customizing icons positive and negative versions
    @Ayo Got it thanks.
  • Issue with grid design and its parameters
    @Pat Styles -> Preset Manager, in Preset drop down select Grids, then it is listed. Select what you want to remove, and "Remove Items"
  • Does snapping not support snap the shape own
    @Li-Xiao said in Does snapping not support snap the shape own: I hope an option for creating polygons based on the length of sides can be added. I added this to the backlog. Snap to the last shape while drawing will work better in the next build. snapping to edges This is a bit difficult for object resizing. It can work for special cases (as in Corel), but we need something like collision snapping that works for movements only.
    @Boldline This seems to be a bug. Will be fixed.
  • Corner editor cursor
    @Li-Xiao @b77 @Kumr This issue can be replicated on MacOS Sonoma. It is a compatibility issue with the new OS, I will try to have this fix in the next build.
  • What does this Artboard Context Menu icon do?
    @Boldline Adjusts the artboard size to the extent of the objects inside the artboard.
  • Context Panel lost - how to restore it?
    @b77 said in Context Panel lost - how to restore it?: @Harry On Windows I think it's View > Workspaces > Default Workspace. Thank you! I didn't think it was that easy
  • Applying zigzag outline effect
    @Kumr Working in new update. Thanks
  • Customizing the contextual menu
    @b77 said in Customizing the contextual menu: that's why it is edited with 'Customize Toolboxes' (plural) I was thinking more of this kind of plural [image: 1700339461014-d2d004cd-b692-4fc4-bd59-e1f5e0e85cdd-image-resized.png]
  • Text on path
    @VectorStyler Thanks.
