      Eraser brush seems to create shaking results and when zoomed in close, near straight lines
      @Boldline Path Editor Show Eraser Shape (and Path Brush and Knife),
      vector with reduced opacity flashes between the lower and full opacity when editing nodes
      @Boldline Not supposed to be happening, looks like a bug.
      South Asian languages support
      @Kumr Thanks for the update. After 1.2 beta is complete this will be one of the things to improve.
      Should custom guides not be selectable unless clicked on directly?
      @Boldline Currently these are just regular objects. I open a bug on this one to have special handling for selection.
      What are these folder options in the settings>folders>folder mode section?
      @Boldline In order of appearance: Preset Collections these are folders containing *.preset (VS) files, you can add these and presets will be scanned from there. Hyphenation custom hyphenation dictionary files. PPD File - Postscript Printer Definition files for VS Postscript printing (not with the host system driver).
      Adding actions to the Actions Panel
      @Boldline The "Append" command should import actions into the panel, but it only works if there is at least an empty actions folder. I will fix this.
      Easy way to warp expanded text or shape to the confines of another shape?
      @Boldline Reverse the direction of the shape. And setting the first not (right click on shape node -> make first..) might also help.
      Bucket fill tool does not seem to work correctly
      @Boldline Got it!
      Last used preferences file not showing up in flyout menu
      @Boldline Oh… it's Preference files. I have only workspaces in my head. Sorry.
      Knife tool issue or just user error?
      @Boldline also no problem here with the knife tool
      Can shapebuilder to only fill the negative space?
      @Boldline Got the file, I will try to fix this ASAP.
      Node's handle will only allow movement along a predetermined angle
      @Boldline Deleting a node between a line and a smooth node could result in this.
      How to delete color stops in gradient panel?
      @Harry Correcting what I said: I restarted to Sierra and AI CS5 has the trash can button there. I guess I always used drag to delete…
    • michaelokrajM
      Adding anchor points / Make a path more complex
      michaelokrajM
      @VectorStyler Meaning this as a compliment, as VS can do everything from my experience: I am surprised we cannot do that until now ;). Also, I am thankful, you add this to the backlog
      Where do I switch options for left-click and right-click controlling fill vs stroke/front or back square, etc ?
      @Boldline A Prefs setting that disables the current mode of assigning colors for the Color bar wouldn't hurt. (It could be that there is such a setting and I couldn't find it). What I'm not so sure of is having a setting that enables the same color assigning method for the Color Palette panel β€” it could be confusing because of the Fill/Stroke button combo in this panel. But I don't use both the Color Palette and the Color bar, so maybe I miss something here.
      Bloom effect – again a bug?
      @Buntstift Send me that file.
    • IgullI
      Context Panel Position
      @b77 Thanks for that, I'll give that a try this morning - he only needs a few tools for "simple" drawings, so trying not to overload with everythingthat comes in the trial download Neil
      blend - Color Rainbow
      @STEVED said in blend - Color Rainbow: Can someone tell me where I can access this Hue angle thingie. In the Color panel menu, select HSB Sliders, then the Hue will be the first component.
      What does the "c" stand for in the descriptor in the upper left corner of VS?
      @Boldline said in What does the "c" stand for in the descriptor in the upper left corner of VS?: Merge does not do this I added this to the backlog.
    • _
      Layer panel scrolls too fast ...
      @_NM_ I reopen this issue. I did change the scrolling speed, but it seems that it is still too fast.
