• Cloning objects.
    How can I make clones of only the original object not the created object? Duplicate the clone
  • vertical text
    @macos The vertical text issue is identified, and the fix will be in the next build. The issue is with the new text engine. If you set the "Text Shaper" option in Paragraph Styles to "OpenType" and then in Character Options enable the "Automatic Vertical Roman" then it should work. BTW: you need to set the "Enable East-Asian Options" in Settings
  • How to quickly copy halftone appearance to new shape?
    @Subpath said in How to quickly copy halftone appearance to new shape?: i think the methode vectorstyler mentioned "save as preset works" best I agree that is currently the best option for getting what I was requesting. I think it's also a great solution long term if you know you're going to use it frequently or in other projects down the road. However, I also think @vectorstyler is right to add the basic copy/paste option for quick and easy one-time editing. Both options will have their due place in VS
  • TEXT enveloppe deform
    ZATOPEKZ
    Thanks it's work fine
  • Copy paste between VS and other applications
    I get the same issue with Affinity designer 2.0 and Affinity Studio When looking in clipboard at the svg of a rectangle copied from Affinity, then pasted in VS and copied to clipboard from VS, I can see a difference : Copied from Affinity : 992x525: <?xml version="1.0" encoding="UTF-8" standalone="no"?> <!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd"> <svg width="992px" height="595px" version="1.1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" xml:space="preserve" xmlns:serif="http://www.serif.com/" style="fill-rule:evenodd;clip-rule:evenodd;stroke-linejoin:round;stroke-miterlimit:2;"> <g transform="matrix(1,0,0,1,-384,-378)"> <g transform="matrix(1,0,0,1,-1176,-147)"> <rect x="1560" y="525" width="992" height="595" style="fill:rgb(235,235,235);"/> </g> </g> </svg> Copied from VS : 238x143 <?xml version="1.0" encoding="UTF-8" standalone="no" ?> <!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd"> <svg width="239" height="143" viewBox="0 0 239 143" version="1.1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" xml:space="preserve" xml:name="Untitled-1"> <defs/> <g transform="matrix(1.0 0.0 -0.0 -1.0 0.0 142.8) "> <path d="M396.1966 18.5092 L396.1966 161.3092 634.2766 161.3092 634.2766 18.5092 396.1966 18.5092 Z" transform="matrix(1.0 0.0 0.0 1.0 -396.19663361 -18.50924665) " fill="#EBEBEB" fill-rule="evenodd"/> </g> </svg>
  • Hotkeys for increases/decreases handles
    @ZATOPEK For making the nodes smooth (or symmetric) there is (shown in the tooltip of the action from the context panel). But for just brining out the handles and moving outwards, no shortcut (and no such feature)
  • Default color parameters for stroke
    ZATOPEKZ
    merci beaucoup
  • Cannot be pasted in situ
    @macos There an option in Settings -> Other Options: "Paste with Artboard Position" If enabled, it should keep the Artboard relative position
  • converting shape text to frame text
    @VectorStyler frame text.vstyler
  • Combine two simple yet overlapping paths. How?
    @VectorStyler Good. Yet I couldn't replicate your solution without selecting Separate Path also ... [image: 1778231945240-5eea44f3-a761-469d-a376-1f5f6da41e9e-image.png]
  • Keyboard shortcut for "Break Shape"-option, how?
    @VectorStyler Ah, great. Got it. Update with a note: One have to check for conflicting shortkeys already set for other operations. Else it won't work. [image: 1778230120509-ee388d5e-42b9-4386-bcc5-a7e4371723f9-image.png]
  • Is there a way to align node handles? (one to another)
    @debraspicher The only problem is that it should change the selected node position, not the opposite one. Il will fix this.
  • Stroke Width Tool freaks out
    @Raaskot I think the small paths and large width causes this. It looks like a bug (should not behave like this). I will try to fix this.
  • New Pen Tools Videos Tutorials
    T
    @Boldline This is a great idea about collecting tips and tricks on this topic. And I really do hope that you are able to make some videos on these tools specifically. If I recall you have been central to bringing about things like the Bezigon tool. I remember really liking it in Freehand but so far it doesn't click for me in VS. Maybe it's that after creating the curves they are normal Bezier handles instead of staying the type of automatic curving that the Freehand version created.
  • Expand Group Opacity question shows no difference
    @VectorStyler said in Expand Group Opacity question shows no difference: @William-Kansepa For some settings changes you may need to reopen the document (and for others, restart the app) I think that could be the reason why it was refusing to work. Maybe an indication to mark that a certain setting requires a restart after editing it? Other software have an asterisk to indicate restart.
    @shomnipotence That looks awesome
  • Is the first option in the arc meant for smaller arcs?
    @Boldline Thanks for this post. I just discovered the option key to change modes and that is very useful
  • How do I keep a certain, chosen brush stroke when drawing new path?
    @VectorStyler Hm, figured it out. It must be set here ... [image: 1777450854829-93c46c12-e929-451a-b581-c04526bd7dac-image.png]
  • Using Mouse to Delete Nodes
    22
    @Ingolf No, I do get it. That feeling is hard to replace. I learned to type on a typewriter so that's probably why I'm adjusted to working with a lot of key travel. I've seen the "drummy" keyboards and they do sound so nice on a good surface and look fun to use. I need my wrists to be stay relatively mobile especially as a tablet user. The Keychrons are not impervious to issues. I had a bit of key chatter on occasion with the Q6 Max when I first started with it probably because of the rubber gaskets, but I think the board broke in enough that it settled because I don't really have a problem now with it. (It did require a firmware update, though)
