  • Grid-It Extension
    @VectorStyler said in Grid-It Extension: creating handles: this seems to add lines and circles where the curve handles are. This could be implemented easily, but not clear what is the use case. creating outlines: not clear what is new in this case, it seems to add an outline to the object. These two are similar to Mark Fromberg's Presenter plugin for Glyphs. They are just like a (vector) visual effect, to make things look interesting. @Boldline To me the grid/guidelines part seems to be the most useful, and can partly be emulated in VS, as the developer said.
  • Cool ideas to add to the guides in VS
    @Boldline said in Cool ideas to add to the guides in VS: The ability to cut a selected guide with the knife tool and then delete one selected section of it or the other The ability to trim guides to the artboard by adding the guides while the artboard itself is selected The problem in case of VS with this is that guidelines are not part of the graphics (layer) hierarchy. They are just "guides". But it is possible to turn objects into guides, in which case the knife / trim tools will work
  • Pull nodes in opposite directions
    @Boldline Yes, same steps in VS, hold Control when scaling the selected nodes: https://recordit.co/zMmUz83C3H
  • Requests for paper size set in VS
    @VectorStyler Thanks Implemented in ver 1.2.001 beta.
  • Alt-click new layer automatically adds selection to that new layer
    @VectorStyler Nice!
    @encart Added to the backlog.
  • Color Picker with magnifier working also outside VS
    @Harry working also outside VS Technically this is doable, but when doing this MacOS will (and should) notify the user if it allows VS to record the screen. And the user must add VS to that allowed list somewhere in the security settings.
  • Making saved points in the history more visually prominent
  • Could/Should items be automatically grouped when placed into VS?
    @VectorStyler said in Could/Should items be automatically grouped when placed into VS?: @Boldline Are these vectors grouped in the other program? Here a few tries from me VS to Affinity Designer 1, no Affinity Designer 1 to VS, yes Clip Studio Paint Vector Layer as SVG to VS, yes VS to Clipstudio Paint as SVG Vector Layer, no Corel Draw to Affinity Designer, yes Corel Draw to VS, yes
    @Boldline I was referring to Pencil 's and Brush Tool 's options in the upper toolbar to add them to Path Brush Tool toolbar also: [image: 1693399043614-obraz_2023-08-30_143722144-resized.png]
  • Tint option in the Color / Palette panel
    @William-Kansepa said in Tint option in the Color / Palette panel: It could be user error on my part, but I can't seem to find the option of changing the tint of a swatch. I notice that there is a different kind of Tint option under Variations, but the one I am looking for should be be under the Color or Swatch panels. What I see is only the Opacity slider. For the purpose of clarity, I will use these screenshots of Affinity Designer as an example. [image: 1693146062162-affinity-designer-colour-options.jpg] [image: 1693146133471-affinity-designer-tint-amp-opacity-sliders.jpg] I found the Tints slider at the bottom of the Colour palette after expanding the palette!
  • Expanding the options for the Path Sketch Tool
    21
    38k Views
    @pentool said in Expanding the options for the Path Sketch Tool: A little off topic, but the reason I don't like those screen recorders is because they don't scale. If you have a big screen, it won't fit into a 13" laptop screen and have to scroll left/right/up/down sometimes to see what people are doing. Yes, your right a youtube video could be a better choice if you need a full screen record. But often you need just a little area and its fast and it get the job done. (ScreenToGif is a 170 kB Tool ) On window you could scale the contend of a browser a bit via Control Key and the scroll wheel.
  • Option to remember fonts recently used in document/most recent
    @Boldline I think this has been requested before, a sort of document specific favorite fonts, but it is marked manually. This will be in 1.2
  • Bug reporting and tracking
    @pentool I think this could be done, after 1.2 is released. I have to consider what tools are best for public bug tracking and how to integrate with this forum (bugs will be still posted to the forum).
  • Option to create single path segments with Pen tool
    @pentool said in Option to create single path segments with Pen tool: You can just press Escape (ESC) to end the line. Interesting, I didn't know that. That's a little more reliable because it's not reliant on clicking at the same time
  • Edit gradient stop location in gradient panels
    Oh yeah, completely missed that. That should work.
  • Allow Print Panel to be expanded vertically?
    @Boldline Added to the feature list
  • Joining at path intersect option
    @Boldline The Trim and Join tool should work for this.
    @b77 said in Could a group that has been combined be listed as such in the layers panel?: Should not the resulting object have 'Group' in the name? Grouping two composite shapes will result in a "Group" label. But after turning one group into a composite group, it will be shown as "Composite Group"
