  • Selecting One Locked Object
    @VectorStyler said in Selecting One Locked Object: @gotanidea said in Selecting One Locked Object: We can select one locked object to unlock it selectively in Illustrator, instead of unlocking all locked objects. I know we can select one locked object through Layers panel, but it would be easier to do it from the viewport Yes, in the menu: Select -> Options -> Allow Locked Objects Thank you, I didn't know about that. It's exactly what I need
  • Slabtype text alignment option
    @Boldline Yes, this is doable with the Alignment panel. It needs maybe more clicks that ideal, will try to improve that.
  • Is it possible to implement these features/ tools in Vectorstyler?
    @visualrevolt Hi, and welcome to VectorStyler. Some of these are doable, but maybe later (after 1.2): B-Spline tool Yes, this is in the backlog (but after 1.2). There is a Smooth Nodes option in the context panel for the Pen tool. Not the same as b-spline, but can click+create smooth curves. Page manager Was not planning this in the roadmap for now. There is the Canvas & Artboard panel but without previews. To preview an artboard, longpress with the mouse on the artboard icon. Group/ Ungroup tab There is in the roadmap a context sensitive / customizable command popover menu, but this is further down the road. Navigation bar There is the navigator panel, and then the zoom / pan / rotate tools at the bottom of the toolbox. Maybe having some of these tools into the status bar (bottom row of the window) could be added. Collapsible Side Panels Added this to the backlog. There is a plan to have panels collapsed to icons. Tool Tabs This is possible already. Just drag the tool group popover from its title knob (vertical line on the left), and place it anywhere on the screen, or dock it on the side. BTW: many of the vertical panels (like Transform, Stroke, etc) can be docked horizontally also, where they change layout.
  • Center view on pointer
    As I wrote in the announcement thread for version .070 centering works perfectly. I assigned they key M for this and I am navigating lightning fast around the canvas now just hitting M to center view now and then.
  • Don't clear/erase thumbnails before updating them
    @VectorStyler said in Don't clear/erase thumbnails before updating them: @Ingolf I will try to improve this, add it to the backlog. And you did well! So much better in .070 - thank you!
  • A node selection issue that slows node editing
    @VectorStyler said in A node selection issue that slows node editing: The problem is that click+drag should be able to move nodes / segments. OK, but by 'click-and-drag' i meant 'box select'. That should not select and bend any segment of any other shape than the selected one. If it's doable…
  • A few thoughts about Color panel
    @VectorStyler said in A few thoughts about Color panel: @Harry Would this mean that holding Control would pick in the spectrum along the same horizontal / vertical axis as the current color? Yes What about the hue spectrum (circle)? It could work as the ruler also - holding control gives perfectly opposite (complementary) color on the circle. But maybe others would have some suggestions?
  • Superselect / Subselect
    @Raven Added to the backlog, should not be a difficult thing to have.
  • EPS option for Illustrator
    @ash-f Added this to the backlog. This is probably doable, bit it is a larger task. AI file format was documented up 1998 for AI7 and AI-EPS.
  • Brush "live" randomization / variation
    27
    42k Views
    @b77, @Harry, @VectorStyler Hi As a source for inspiration, for modulate Strokes, the painting program Black Ink came to mind. "Black Ink" uses a kind of controller nodes to modulate brushes to set and control random strokes and has a node system for layers. [image: 1670593437191-black-ink-1.png] Here are some videos Video about the Brush Controllers: Black Ink Brush Controllers Video about Black Inks Layer Nodes: Black Ink Layer Nodes Scattering a Brush may also be interesting her a Video about it Scattering a Brush with Controllers
    @Raven said in "Zoom Tool Click Zooms Out" preference to also work with the temporary zoom tool: doesn't recognise the addition of the Option key for zooming out Yes, this is caused by deactivating the temporary zoom if other keys are pressed. I added this, will try to fix it ASAP.
  • Option to pin open the dialog box for icons in the UX
    @b77 yes that is true... and maybe that is the best solution. Part of me likes the ability to just open it and have it there as opposed to tearing it off and finding a place for it.
  • Effects "Randomizer"
    @Harry , @b77 can not resist to contribute to this Do you know Native Instruments "Reaktor"? A program that allows you to create your own software synth maybe VS will look something like this in the future ? [image: 1670439157079-reaktor-synth.png]
  • Reconsider some value sliders
    @Jayanta-Das said in Reconsider some value sliders: In Affinity Designer it is Alt+Ctrl+Left Click and drag. This is very usefull if I set this key press combination in Wacom pen button then I can simply click the button, hover over and move left and right to resize brush. Recording Problem with these Affinity multi-key shortcuts are that they are so easy to forget and incredibly annoying to hold down. Photoshop + Capture One Pro: right click, easy to use pop-up with options and preview of size (at least in CO), done. Impossible to forget, easy to use.
  • Adapt some Preferences options on first run of the app
  • Using more distinguishable terms in the palettes menu
    @Boldline Yes, this will be renamed.
  • "Live" preview of transform values
    In Color panel there is a lag between opacity slider movement and object's opacity change. On the other hand, in Object/Object Options pop up, there is smooth opacity change - that's I like - but lag with slider circle.
  • Toggle shortcut for Greyscale display mode
    @Ingolf said in Toggle shortcut for Greyscale display mode: I could easily live with a static one with a 'refresh' button. This is easily doable, as image histogram extraction and histogram view (separately) already exists.
  • Duplicating Guides by Using Ctrl+D
    Ok my bad - I misunderstood. I was copying objects.
