      Lines: spacing... functional ?
      @Pat This issue should be fixed in build 1.1.072
      Oval Shape panel not resetting?
      @Boldline This issue should be fixed in build 1.1.072
      Activation of Boolean operations
      @Wurstkäs This issue should be fixed in build 1.1.072
      Grouped clone disappears after double clicking
      @Harry This issue should be fixed in build 1.1.072
    • IngolfI
      Prefs - Performance - Hovering selection
      @Ingolf This issue should be fixed in build 1.1.072
      Shapebuilder tool still big problems with UNDO
      @MajorTom This issue should be fixed in build 1.1.072
      Effect-->Replace colour--> Colorize : bug ?
    • R
      Panel graphic popup menus displaced if on second monitor
      @Raven This issue should be fixed in build 1.1.072
      Pen tool
      @Jayanta-Das This issue should be fixed in build 1.1.072
      Rectangle panel hover info not correct
      "Cotton buds" line style with stylus - after upgrading to build 1.1.067
      Text Drag Option Not working in Build 67
      Clipping Group regression
      @William-Kansepa This issue should be fixed in build 1.1.072
      Brush color switches to white when change is made to brush size with bracket keys
    • encartE
      When changing the shortcut key, the letter keys allow you to enter text
      @encart This issue should be fixed in build 1.1.072
      Undo after applying a colour gradient
      Smooth node mode bug?
      If transform selection box is not set at 90 degrees, it creates a wonky offset path
      Pattern Brush from Blends seems to be broken
      @Subpath This issue should be fixed in build 1.1.072
      Text on a path seems to have issues when you flip to opposite side
