    • IngolfI
      Polygonal spiral placed offset
      Works perfectly now, thanks.
      Occasional inability to change the artboard color with toolbox tool
      @VectorStyler Looks like you were way ahead of me on this idea! I realized you add this in the newest build. awesome!
    • IngolfI
      Windows build .61 - clone disappears
      Fixed.
      dragging the layer in layer panel
      @VectorStyler Yes, Improved a lot.
    • IgullI
      Point snapping to group broken
      @VectorStyler said in Point snapping to group broken: @Igull This issue should be fixed in build 1.1.062 Yes, definitely working now, thanks. Neil
    • IgullI
      Opening AI Document with embedded PDF
      @VectorStyler said in Opening AI Document with embedded PDF: @Igull This issue should be fixed in build 1.1.062 Definitely fixed now, works well ! Thanks Neil
    • IgullI
      Move Node Broken ?
      @VectorStyler Works a treat - thank you !! Neil
      Changing colors from gradient panel
      @Jayanta-Das Yes, this is a regression in the current build. Will be fixed ASAP.
      Shape builder tool bugs
      @VectorStyler Fixed. Thank you.
    • IngolfI
      Show palette bug
      Fixed
      Stroke Width Panel, Randomize Profile Preview does not work
      @Subpath This issue should be fixed in build 1.1.062
      Calling the Panel "Adjust Profile with Mask, could cause a Crash
      Applications shortcuts menu width spacing
      @Boldline This issue should be fixed in build 1.1.062
    • encartE
      [Text typing] The enter-key adds a blank line between lines of text
      @encart This issue should be fixed in build 1.1.062
      Gradients, the node with the last fill color is no longer selected
      Unintentional change of the stroke width
    • T
      UI measurement issue
      @typeglyph Pica number formats should be supported now.
      oddity with the gradient for strokes
      Cloned Stroke no longer there after reloading the file
      Cropping artboard issue
