    Just a Pattern
    69 Posts 8 Posters 61.2k Views 8 Watching
    • M Offline
      marce @Subpath
      @Subpath Great thread and posts. Thanks. Forum says "you can upvote a user only six times per day", so sorry guys i didnt give the like i wanted meanwhile reading.
      Memory 48gb ddr4
      NVMe CT100p 1TB
        Subpath @marce
        @marce said in Just a Pattern:
        @Subpath "Forum says "you can upvote a user only six times per day",
        Very curious, didn't know that.
        But dont worry, if my post inspire people or
        are helpful then this is fine enough 🙂
          Subpath
          Created using:
          The colorize feature in the Repeater, which can also colorize strokes with a bitmap.
          (See Manual how)
          The Style Picker Feature, which allows you to transfer style attributes
          from one group of objects to another.
          You could take look at this Link
          https://www.vectorstyler.com/forum/topic/5851/a-style-picker-tool-feature-and-a-few-strokes
            Subpath
            I used a shape with a multi-colored gradient to colorize a bunch of strokes using the Repeater,
            and transferred the color (style)—using the new Style Picker Tool Feature— to a bunch of
            other Strokes created with the Blend function.
            The strokes colored with the Repeater
            Here the Result
            1 Reply Last reply Reply Quote 8
              Subpath
              Took a a gradient from another App with a screenshot and use
              this raster graphics then to colorize a bunch of strokes with the Repeater.
              This time no Style Picker Feature where used.
              I create a a color Palette instead from that bunch of strokes
              (create Palette from selected Objects)
              and colored a Swirling Lines Shape after converted it to curves
              via Colorize with that new palette
                Subpath
                Made in Vectorstyler, recreate a pattern i found on the Internet
                mine look a bit different but i am fine with that
                For anyone who is interested, you need to split the Line
                in different pieces to create this pattern
                  Subpath
                  I more or less replicated a pattern I found online.
                  I couldn't resist using the "Along Stroke" feature
                  in VectorStyler's gradient editor.
                    Subpath
                    This was inspired by "string art"; I wanted to experiment with creating it
                    as vector graphics and applying gradients to the individual paths to see
                    what kind of patterns would emerge.
                    The String Art was made in Nodebox because its very easy to
                    create Point/Node Pattern with it.
                    https://www.vectorstyler.com/forum/topic/4119/a-kind-of-patternnodes-for-windows-free-win-mac
                    The coloring was created in VectorStyler; which allows to create gradients along a path
                    and allows them to be applied to the design's paths using the "Style Picker" group function.
                    L 1 Reply Last reply Reply Quote 3
                      Subpath
                      Another Variation of it
                      M 1 Reply Last reply Reply Quote 2
                      • M Offline
                        monsterfox @Subpath
                        @Subpath These graphics look quite unique. I’m curious: can VectorStyler create them at the moment?
                          Subpath @monsterfox
                          @monsterfox
                          I think some of the Designs would be possible in Vectorstyler
                          all you need is a straight Line, rotate it a bit and copy and repeate it
                          But i think it is way easier to do it in Nodebox because one would have more Options
                          when you could set single Points and connect those Points with a Line i dont think
                          that Vectorstyler could set single points.
                          To set single points and connect them its very easy in Nodebox. (Nodebox is free, PC and Mac
                          in the mean time there is also a Version for Silicon based Macs )
                          All you need is a Path and a Point Node which say how much Points a Path should have.
                          This way you could create all kind of Point Patterns and connect them.
                          Here how the base Structure is made
                          and here the whole Design
                            Subpath
                            Some additional notes regarding Points in NodeBox:
                            Points serve not only to connect lines or paths.
                            They can also be used to specify positions for shapes or designs.
                            And since this all is Node-based in Nodebox, it is very easy to replace
                            one shape with another or to modify the design.
                            Not to forget that Nodebox is a pretty good compainion to Vectorstyler
                            NB has .SVG and PDF Export and you could import .SVGs
                            M 1 Reply Last reply Reply Quote 1
                            • M Offline
                              monsterfox @Subpath
                              @Subpath This is a node-based program, which I’m afraid won’t work for me. Just like creating materials in C4D, it requires connecting nodes. This kind of workflow isn’t my strong suit.
                                Subpath @monsterfox
                                @monsterfox
                                No problem if it doesn't work for you or isn't a good fit.
                                I only use it for specific tasks myself. Creating vector graphics using nodes certainly
                                has its merits and its fun to use. I didn't find the basic principles hard to learn—and
                                I’m really not the brightest bulb.
                                  Subpath
                                  The design was created using Nodebox (which is free).
                                  I tried to copy and scale it within VectorStyler, but I couldn't find
                                  a way that produced a good result.
                                  However, the coloring was done in VectorStyler—and this is where
                                  the "Style Picker Group" feature really shines. The design consists of 80 objects;
                                  I created a single stroke, applied a gradient along a path, and then duplicated
                                  it until I had 80 copies.
                                  Finally, I grouped the design elements and the strokes, and then applied the styles
                                  to the whole set using the Style Picker.
                                  • L Online
                                    Li Xiao @Subpath
                                    @Subpath said in Just a Pattern:
                                    VectorStyler can actually create this. I'll take some time to record a video
                                      Subpath @Li Xiao
                                      @Li-Xiao
                                      No problem, just take your time.
                                      I’m very interested to see how you solve this—
                                      and I imagine other users are, too.
                                      In my own attempts, VectorStyler always distorts the shapes being duplicated;
                                      maintaining consistent spacing between them also proves to be an issue.
                                      Here how the Result looks in Nodebox
                                      • L Online
                                        Li Xiao @Subpath
                                        This is quite easy, just use the Blend Tool
                                        This is the specific example I was referring to for the video I plan to record.
                                          Subpath @Li Xiao
                                          @Li-Xiao
                                          I wouldnt recommend to take the Blend Tool for the first one.
                                          Made a little Tutorial how i made this one which i made in Vectorstyler now
                                          Here the Link:
                                          https://www.vectorstyler.com/forum/topic/5951/a-little-tutorial-how-i-made-and-colored-the-curved-polygon-in-vectorstyler
                                          L 1 Reply Last reply Reply Quote 2
                                          • L Online
                                            Li Xiao @Subpath
                                            @Subpath
                                            I first tried duplicating a line along a path with the Repeater it was close, but not quite right. In the end, I used a Grid shape with an Envelope effect. Attached are a brief video demo and the source file for reference.
                                            https://youtu.be/3Pm0DL2eevo
                                            https://drive.google.com/file/d/1PXxuUuBCzqWX3qU6mv5T4FR148ZrN8Wa/view?usp=drive_link
                                            Envelope.vstyler
                                            S 1 Reply Last reply Reply Quote 3
