    289 Topics
  • Color palette panels grid margins
    @Ayo Seems that popup palettes do not use the option. I will fix this, and also place it into settings
  • Weird transform behaviour when altering fill color
    @Raaskot It is a refresh bug. Use Control+R (Windows) or Command+R (Mac) tor redraw. I will try to fix this ASAP.
    @Boldline said in Brush tool switches to different saved brush when width is scaled from Brushes panel: Would it help to send the workspace files? Yes, please send me those files. It could be some settings issue.
  • Bug
  • Tiny dropzone at the bottom of Layers panel
    @debraspicher I will try to improve this.
  • Appearance Panel>Opacity not responding to scroll wheel
    @debraspicher said in Appearance Panel>Opacity not responding to scroll wheel: May I suggest to move the slider so that when it is popped out, the knob/slider portion is just below the mouse cursor (provided there is space). I will try to add this.
  • Screen Glitches when Erasing Text Completely
    @debraspicher said in Screen Glitches when Erasing Text Completely: I opened a bug on this.
  • Node handles still disappear occasionally
  • Nodes behave odd in preview vector view
    @Raaskot Seems to be a bug.
  • exporting slices
    @wbjp I will try to fix the crash for the next build.
  • Crossing Gap did not work well with Dashed Lines
    @VectorStyler File sent
  • Replacing color of layer color guide seemingly not working
    @VectorStyler said in Replacing color of layer color guide seemingly not working: @Boldline said in Replacing color of layer color guide seemingly not working: Right now it still selects everything If you select the objects, then it should be limited to those objects only. Yes that is correct - I was thinking about the possible way to choose specific artboards to limit the scope to - if someone used the artboard tool and selected specific artboards to replace color on - only the selected artboards and their contents would be affected
  • Repeater
    @VectorStyler https://youtu.be/YfQfUv2k-e4?feature=shared The actual situation here with me is the video effect.
  • Small spelling error in Snapping Options
    @debraspicher said in Small spelling error in Snapping Options: Formation Angle Will be fixed.
  • Panels stop extending all the way to the end of the screen
    @JuurGroove I will try to replicate these issues.
  • Guidelines Panel tabs overlapping
    @VectorStyler It's hard to say because the tab was hidden until I activated it to delete some guides. I'm thinking it was from one of the rescale events we have talked about... it did not recur in this case because I had went ahead to adjust it. I had thought maybe it was glitched.
    @VectorStyler I've found a workaround while waiting for the update. However, one can't use the design with the Repeater (or Pattern) feature. It's as if the envelope shape effect no longer applied to the original object.
  • Still can't export jpg/tiff at 400 dpi
    @VectorStyler said in Still can't export jpg/tiff at 400 dpi: @William-Kansepa Can this issue be replicated still in the latest builds? There have been some improvements with the large image handling, but I could not replicate the transparency mask issue. Yes, sure there has been some great improvements in the latest builds. Thank you so much! Sorry for the delayed response as I have been away and not doing any VectorStyling
  • Miss Stripes in Stroke Panel
    @VectorStyler Got Stripe back, thanks (It's been very, very a long time since I used these Arrows so I forgot about it)
  • [Data Source] Selecting text in textfields
    @encart I'm trying to replicate this with some test data, but variable text selection seems to be working in this case. Can you send me the file form the recording? Thanks!
