    288 Topics
    This issue is now resolved! Thank you @VectorStyler!
    @Boldline @Subpath this is a bug, will be fixed ASAP
    @Bashu619 I opened a bug on this and will try to fix it as soon as possible.
  • Simplify Path bug
    @Comet I added his to the backlog as a bug
  • Applying brushes to SVG behaviour
    @VectorStyler I used brushes since is what I see it works in other programs. I will try the strokes
  • Tibetan fonts are displayed as squares only.
    @Martin-K said in Tibetan fonts are displayed as squares only.: Also, it seems to me that Vectorstyler is not 100% OS X native - is this true? It is 100% OSX native, but not all OSX features are used. Can you send me a file with that Tibetan text? Thanks!
  • Select by color causes sporadic movement when selection dragged
    @Ridgehammer Can be replicated. It seems that the objects are selected two times (shows 6 selected in the status bar). This is a bug and will be fixed ASAP.
  • Contour Preview is wonky
    C
    I used the drop down menu, Effects/Contour/Contour Options
  • VS not printing at all.
    @marce I opened a bug on this. Printing was tested very recently, and it has been working. Could be a regression.
  • Strange behaviour with a bitmap with fx and perspective
    @marce This seems to be a bug, I will try to fix it as soon as possible. Some distortion effects on images are problematic at clipping boundaries
  • Object suddenly disappear
    I am also occasionally experiencing the same behaviour.
  • Path Brush Tool - Adjusted bugs
    @VectorStyler Thanks! The issue is fixed!
  • Cannot position the starting XY of page grid
    @pilkafa said in Cannot position the starting XY of page grid: However, I'm still seeing grids follow the bottom down alignment This might be a bug, I will try to fix it as soon as possible
  • Panel bugs in 1.3.003
    Confirmed fixed in 1.3.004 - thank you!
  • Intertwine Tool doesnt work since Vers 1.3004
    @VectorStyler i never did it this way and it was always working by using the intertwine tool directly see video here the only difference i see between this two ways is when using Styles -> Intertwine -> Create ... no dialog pops up i update to Version 1.3.004 and the Intertwine Tool is working now, dont know what was happen before
    @VectorStyler here is a video of me trying it with the keyboard shortcut. I noticed the node tool and selection tool were alternating being highlighted back and forth...instead of it actually grouping the objects, it jist switches back to the other tool
    1k Views
    LoginErrorL
    @VectorStyler There are some unexpected behaviours showing up when trying to export like this, but I will make a separate bug report post and proof and concept for that later.
  • Scrubbing is not working properly.
    DanielD
    @VectorStyler: The problem is with pen tablet.
  • Lag related to amount of artboards
    @VectorStyler I will test the Canvas spreads, thanks very much!
  • Lag when using a text frame linked to multiple other text frames
    @marce said in Lag when using a text frame linked to multiple other text frames: @Boldline Hi! I made a video. But someone sent me a whatsap and it become recorded, and must delete from the post. Haha, sorry. Even that, the files i made are pretty standard. The archive that lags are text frame with the filler text. Im attaching here. 0_1765816294189_Probando multiple artboards.vstyler There will be improvements for this in the next build
