    291 Topics
    @VectorStyler Thank you for your response. Please note that the lag takes place when you long press the bracket keys.
  • Intertwine Tool doesnt work since Vers 1.3004
    @VectorStyler i never did it this way and it was always working by using the intertwine tool directly see video here the only difference i see between this two ways is when using Styles -> Intertwine -> Create ... no dialog pops up i update to Version 1.3.004 and the Intertwine Tool is working now, dont know what was happen before
    @VectorStyler here is a video of me trying it with the keyboard shortcut. I noticed the node tool and selection tool were alternating being highlighted back and forth...instead of it actually grouping the objects, it jist switches back to the other tool
    1k Views
    LoginErrorL
    @VectorStyler There are some unexpected behaviours showing up when trying to export like this, but I will make a separate bug report post and proof and concept for that later.
  • Scrubbing is not working properly.
    DanielD
    @VectorStyler: The problem is with pen tablet.
  • Lag related to amount of artboards
    @VectorStyler I will test the Canvas spreads, thanks very much!
  • Lag when using a text frame linked to multiple other text frames
    @marce said in Lag when using a text frame linked to multiple other text frames: @Boldline Hi! I made a video. But someone sent me a whatsap and it become recorded, and must delete from the post. Haha, sorry. Even that, the files i made are pretty standard. The archive that lags are text frame with the filler text. Im attaching here. 0_1765816294189_Probando multiple artboards.vstyler There will be improvements for this in the next build
  • 16 bit .bmp file crash or are wrongly displayed in VS
    @VectorStyler 0_1765789920580_marce.zip Here it goes
  • Merge Boolean does not create clean edge
    @Ridgehammer I opened a bug on this and will try to find a solution
  • Importing SVG with embedded bitmap
    @marce said in Importing SVG with embedded bitmap: @EricP Thanks your help!! Good result. I opened the file you attach. But... what you did? Explain it to me, please. I figure it, reading the other thread. Thanks a lot again!
  • Text Wrap Behaviour
    @marce I opened a bug on this
  • Importing rtf issues
  • Issues remaining with the Drop Shadow
    @Boldline I will try to improve these
  • Regression in 1.3.002
    I am happy to say this issue has been resolved. Things are now working as expected in VS 1.3003. Thank you @VectorStyler.
  • Another regression
    Issue has been resolved in VS 1.3003. Thank you @VectorStyler.
  • Long-tap on tool in toolbox doesn't consistenly bring up flyout tools
    Right-clicking the icons also works, at least on the Mac. That is my own preferred method as it is quicker than a long press and provides a bigger target than the tiny arrows in the corners.
  • Erratic halftone editor in 1.3.002
    @VectorStyler said in Erratic halftone editor in 1.3.002: Yes, and this this consistent with double clicking on other tool icons. I was thinking the same behaviour as the shape effect tools. Double clicking on tool icon while a shape with effect is selected opens (or puts forward) the shape effect panel, allowing user to change the parameters. With halftone, the appearance panel could be put forward, allowing user to change halftone parameters of already created effect. The issue is with already created halftone, the user may think the dialog opened by double clicking may be used to change settings (and it does in preview), but then clicking ok undoes the changes, which is confusing.
  • Erratic Repeater editor tool in 1.3.002
    @EricP I will try to replicate this
  • Interface issue
    @B-Vs-V Yes it is a regression, was reported by others also. Just fixed it, fix will be in the next build
  • Some fonts are displayed, when you use them, you cant select it later.
    @marce I will try to replicate this.
