• How can I scale type and line space proportionally?
    Uploaded sample file. Im scaling the box with Alt-Shift-drag The textboxes just acts completely unexpected in this video: Sample video 0_1707132471295_tekstvalg-03.vstyler.zip
  • How do I generate screen dots from blurred shapes?
    @Raaskot I know you can create something like this and more with the Repeater. As you can see in this thread, for example. https://www.vectorstyler.com/forum/topic/2295/repeater-halftone-problem-on-rasters/53 . . But anyway, here is a little Online Tool that also has something to offer. The result can be saved/downloaded as SVG. https://labs.adobe.com/experiments/hello-halftones/ Here yet a old Thread of mine about that Tool. https://www.vectorstyler.com/forum/topic/1089/tip-halftone-generator-bitmap-to-vector-graphics-svg/4
  • Pen tool behaviour when extending an open path
    @Raven said in Pen tool behaviour when extending an open path: Is there a preference or modifier key that governs the behaviour? In the context panel, uncheck "Adjustments" Cannot seem to get the node being moved with the spacebar method to snap to the segments or nodes of the same path (if snapping is enabled). Yes, there seems to be an issue here, I opened a bug on this one.
  • How do I see brush stroke pressure profile in real-time?
    @VectorStyler: I am using VS 1.1. I reckon it is in 1.2 Beta? Don't answer that: I found it! Thanks to @Subpath and @Boldline's screenshots!
  • Meaning of less than 1 pixel
    D
    @VectorStyler Thank you for the explanation. I suspected the precision might be related to internal calculations. I appreciate your time in confirming that is the case.
  • Does VS have a scaling brush?
    @Boldline said in Does VS have a scaling brush?: very excited to see what improvements with repeater that VS will offer! me too
  • Organizing VS for easier understanding and use of styles and presets
    And… there's no need for icons in the 'Save Style' dialog — a checkbox with a text label that says 'Global' (or anything descriptive) would work great, IMO.
  • Preview
    28
    41k Views
    @Pat I managed to replicate the preview issue in Windows 11. It seems that the Windows 10 preview solution does not work on Windows 11 file explorer. Not sure yet what causes this issue.
  • Delete Custom Created Presets Style in Image Trace Tool/Panel
    @oleGraf said in Delete Custom Created Presets Style in Image Trace Tool/Panel: Yes I am working with version 1.1.118 for Mac I will add the trace preset listing to 1.1 also.
    Cool, thanks! [image: 1705730539545-9505f3f2-ab71-4ba6-b2fb-a267e60e881d-billede.png]
  • What is the most accurate and easy way to slice this type of shape?
    @VectorStyler Thank you! I don't know why I wasn't thinking of the combine operations for this. I appreciate the reminder!
  • Spacing between Objects
    @VectorStyler Thank you for changing to positive values. @VectorStyler said in Spacing between Objects: @Kumr said in Spacing between Objects: I noticed that the values to be in negative to get the spacing, it would help (for my mind) if it is other way around? I will change this.
  • Hide overlapping panels in viewport
    @Raaskot Tab key for hiding panels should work in 1.2 beta
  • Text cursor almost invisible: Just a one-pixel dot.
    @Raaskot Yes, I found the error. it is in 1.1 only, 1.2 should be fine. I will provide a fix for this and others soon.
  • When copy paste a layer -- layer name is altered
    @b77 said in When copy paste a layer -- layer name is altered: need to use 'Copy' from the Edit menu That makes sense. Though still missing the layer structure transfer things work more as expected when using menu-copy. Yet I acknowledge fully your suggestion to @VectorStyler.
    @Subpath Cool, thanks!
    @Raaskot Meanwhile I managed to replicate the issue and found the root cause. The fix will be in the next build. The bug affects the strokes resulting in the blend object. The transform panel option @Li-Xiao was refering to can be found in the panel menu. Another way (workaround) to enable stroke scaling is to enable the Object -> Object Options -> Geometry -> Transformed Stroke on the group.
  • Why is the New Layer Preview default an Orange fill?
    @Kumr I think this is normal. It magnifies the layer, so, when the layer is filled with objects, you can see the things that are in the layer.
  • Couple of Palette Questions
    @VectorStyler said in Couple of Palette Questions: Otherwise, it can be removed in the Styles -> Preset Manager. Ahh! that's where that is! Thank you, sir.
  • How can I make precise reflections with the Reflect tool?
    @VectorStyler It would be nice if you make the first click you will get an sort of pivot icon and if you click on the icon you can still drag it around (to correct your first click) and that this pivot icon can snap to guides, shapes etc.
