    @Boldline said in Live text that is modified and copied and then pasted over text on path does not retain edits: would I need to alter it in the appearance panel instead? I think this this case you need to use a character scaling option from the Character Panel (expanded mode of the panel). Also, there is a Settings that changes the character scaling when scaled with the Transform tool.
  • Coordinates top-down direction as default?
    @creative When you create a new document with the "New Document Setup", all the settings changed there will be defaults. There is a "More Options" button on the right side, if you scroll down.
  • Creating and using guideline groups?
    C
    @VectorStyler said in Creating and using guideline groups?: I think what is needed here is document templates. Just set up a new document with guidelines and everything else needed, and then save it and use it as a template with the New Document Setup. Thank you very much, that's probably the best way. With so many great features and functions in VectorStyler, it's easy to lose track.
  • Document presets backup?
    C
    Mac, I looked at the reveal workspace but include those files there the dozens of new document presets I created? The Presets Manager seems to be the better way.
  • Disabling path brush strokes from joining
    DanielD
    Thanks very much! I will try this and let you know.
  • VS now crashing after settings change
    Devil DinosaurD
    @Tonyrambler It should work now. I had the same issue with my previous MacBook and choosing "Metal" was the solution.
  • Controlled thick and thin lines
    @Jackamus said in Controlled thick and thin lines: How do I draw a new ellipse without any previous attributes? In VS the previous attributes are used when drawing new objects. In this case you can clear the width profile on the new object by clicking the solid stroke icon in the stroke panel (second from last).
  • VS startup time
    28
    35k Views
    @Harry said in VS startup time: Where are the temporary files located in Windows? It is up to the operating system to serve the temporary file locations and this may vary between versions. VS will still clean the temporary files, but it does so after crashes, and not at startups. With normal exit, VS will not leave temporary files.
  • Rotating linked vector files
    @chessboard This issue should be fixed in the new build 1.2.018
  • How to create own document preset groups?
    @creative The current "New Document" view cannot define new groups of presets. It will list all document optins presets in a single flat list. I will improve this ASAP.
  • PDF X
    @michaelokraj I will add a separate PDF/X export before 1.3
  • Changing tooltip font size?
    @creative Tooltips are handled by MacOS.
    @Boldline Use the "Isolate Inside" (double click) to edit the content of a group. I changed the order of the selection (members first) for the next build (it is just a resource flag), lets see how it will work.
  • How to convert pattern to shapes?
    Thanks for the quick response. Ah, I did try that but silly me; I didn't see that what was generated was actually a group with all vectors inside. Sorry for that. Nice to see it's possible. Have a nice weekend!
  • Regarding the issue with the applied effect of the Repeater
    @VectorStyler Understood. If there could be a simulated expansion, it would solve this problem by preserving the non-destructive effects and applying the final effect to gradient content after the Repeater.
  • Adding white noise to a specific color in a color gradient
    22
    29k Views
    @VectorStyler Thank you That's what I was doing but had forgotten about this single/double click... hence my lack of understanding.
  • Setting default styles for created paths and shapes?
    @LoginError said in Setting default styles for created paths and shapes?: Is there any way to update the default style when that option is unchecked? Just select a color on the color panel, or a gradient in the gradient panel (without an object being selected). A style selected in the Styles panel is not going to be used as a default regardless of settings.
  • Saving objects as "assets"
    @Pat Copy-paste from AD goes through PDF, and that means the flattening of attributes like multiple fills, strokes. Gradient may go through if linear of circular. But noise will become image as there is no noise attribute in PDF. The internal format of Affinity is not known, so VS cannot import that. But VS can import Adobe Illustrator assets.
  • User interface is huge
    @Nephilim983 Thanks for the description. I will try to create a similar setup to replicate this issue.
  • How do I reset the gap between the dashes (dots) to even spacing?
    thank you for the video, I must have some other setting wrong elsewhere because when I do those steps, I still get the odd spacing. here is a video of my attempt I will try on my other computer and see if I have the same issue so I know if it's a setting here on the first machine that I have wrong UPDATE: I see where the issue lies - I was going back to another setting in the dash dropdown and that was resetting the number of spaces again. Thank you for your help!
