• Post support question here.
    Locked
    I think I figured out what I was doing wrong; I was using the tool on a layer that was highlighted, while a different layer was selected. The layers had objects that overlapped, and I thought the tool wasn't working. In short: User error .
  • Display text size in points
    The 24 pt size should show as 0.33 inch (maybe the field is small and the 0. is not visible). Will add a separate unit option for font sizes as this is a problem.
  • Drag-and-drop produces document in floating window...
    D
    Got it...I don't know how the floating window was created initially, probably ID10T problem; it works as you suggest above. Thanks for your help.
