• gradient for brush stroke disappear
    ZATOPEKZ
    @VectorStyler merci pour l'information
  • Older versions are also showing in Installed app list
    @Jayanta-Das Remove those. There have been (and still are) some issues with the MSI installer. I will try to find a solution for this.
  • Issues working with Pattern Brush and Bitmaps
    Here is a larger version of the brush resource if it may be helpful for the purposes of internal testing: @2x grass resource
  • Dxf import
    @Steve-Haley said in Dxf import: was led to believe that this version could directly import DXF files. There is no DXF support yet, and none mentioned in the documentation or website. DXF support is planned for version 1.3
    Thanks for the info everyone. Just to clarify; I really would like to use this to switch brushes (in several software) (so not only to have having different settings like sensitivity curves in Wacom). Looks like this Tool ID feature to switch brushes is already possible with Wacom since 2017!! And at least available in software since 5 years ago (!) as seen in this video by Aaron Rutten of 5 years ago where he literally does switch two wacom pens to switch brushes and talks about this in the video below: youtube video
  • Enhancing Workflow Efficiency in VectorStyler
    @jammessbol However, I sometimes find myself spending too much time on certain repetitive tasks. What kind of repetitive tasks? Some examples might help to find a good answer.
  • Accidentally changing a value in an input field
    @Subpath Got it. this occurs if highlighting in a field that did not have the focus. I will try to find a solution for this.
    @Boldline Not currently. The outline preview will render white outboard. This can be added as an option to show the color.
    @Boldline This is be easy to fix, but it will then change default behavior. Currently this is by design (default for zoom, pan and rotation). I will add an other action (maybe set to Command-0 by default) that only resets the zoom and panning to fit into screen
  • How to use this tool?
    @monsterfox That tool should not be listed among the actions (something internal). The correct simplify path tool is in the toolbox (3rd tool group).
  • Questions about Puppet Warp tool
    @Yaoif Yes, it is called Elastic Warp. Can be added as a shape effect and then edited (similar editing as in Illustrator).
  • Good brush parameters for non loosing color after one stroke ?
    ZATOPEKZ
  • compatilities betwen AFFINITYDESIGNER brush and VECTORSTYLER brush ?
    ZATOPEKZ
    thanks for this information
  • How do I make copy/paste overwrite text work?
    @Raaskot I opened a bug in this, will get back soon.
  • Best way to achieve this effect?
    @VectorStyler and @Subpath, Thanks! I will try.
  • Stutter
    @monsterfox I will try to find a solution for this.
    @Boldline yes, this seems to be an error.
  • Adjustment layer halftone affects more than just the artboard
    @Boldline It will render the whole visible (or exported) area. This is basically the whole layer, the artboards are just guides for printing / exporting (Same goes with any other drawing). Adjustment effects can be restricted to an area or any shape, by drawing an object, adding the effect ti the object (as a regular image effect) and turning the object into an adjustment layer (in Object Options)
  • How do I reset the settings of the eraser panel back to the default?
    @Boldline said in How do I reset the settings of the eraser panel back to the default?: It would make more sense if "default was listed instead of it always saying "custom". I will try to change this.
  • How to use the Settings linked files
    @VectorStyler ok I think I understand. The file gets stored here "behind the scenes" but we look for the custom settings found inside the folder(s) where we adjust the settings file and workspace drop down buttons in the context panel. makes sense now - thank you
