• Polygon tool - where?
    @jsampson45 your welcome No matter what is showing here this is the "Smart Shapes" Section i.e they could be further be editied via the Shape Panel The currently selected Shape will be displayed at the bar. Note this little Triangle on right here which always mean there are some more Tools [image: 1721907071928-triangle.png]
  • "Open Recent" list empty after updating to newest build
    @VectorStyler Yes - after I opened a file I had used previously and then saved the updates to it and then closed it and restarted VS, it now shows in the "Open Recent" - but none of the other files listed prior to the update are there [image: 1721745840095-9a63d567-a36b-4b8b-8f41-dfdf492d50d3-bld-2024-07-23-at-10.41.46.png]
  • Save multiple effects (as a style?) and apply them to an object
    @Pat said in Save multiple effects (as a style?) and apply them to an object: Object Style can be created using the (+) button in the Styles panel, that opens a style kind selection menu Please send a file with the object that causes this crash (there must be an object to create a style).
  • Export to .PSD
    @Kemelvor Moho looks cool, seems also that it have an impressive Feature Set
  • Memory loss
    @Ayo Yes, the cause is the number of nodes (not available as a setting). I will try to find some solution to show some nodes even for these cases.
    @Boldline said in VS does not currently update live text font when grouped when missing font is activated externally: Basically - is it possible to have VS update missing fonts despite it being grouped? Grouping should not affect this. I will try to replicate this issue, it could be a regression.
  • Inconsistent Polygon Rotation Angle
    @_NM_ said in Inconsistent Polygon Rotation Angle: a 5-sided Super Shape appears at a 180 degree rotation relative to a pentagon drawn with the Polygon tool. I will loom into this, and fix it if possible.
  • Deactivate preset folder but keep it in sight?
    @Ayo said in Deactivate preset folder but keep it in sight?: Button 'Export Group' in the Preset Manager means export the whole group of all the presets This should export only the types in the current group. I will open a bug on this to verify it.
  • Save Palette > Vectorstyler Default format
    @Ingolf A split to Save (without formats) and Export (with formats) sounds very clear and helpful
  • It is HSL not HLS
    HSL it is now, many thanks!
  • Unsolicited process color swatch appearance
    @Ayo said in Unsolicited process color swatch appearance: Process Color (cut corner) can end up in an RGB document and associated palette Both process (global) and spot colors may end up in RGB documents. These are colors that are linked to the palette (changed in the whole document, if the palette is changing). When printed, these are converted on the fly to CMYK. Also. the palette allows colors to be stored in other than RGB format when the document is in RGB (same for the rest of the document).
  • Splash screen says build 32 and auto-update says it's build 33
    @VectorStyler No problem, thank you for confirming.
  • Direct access to preferred palette for layer color selection
    @Ayo said in Direct access to preferred palette for layer color selection: First Color with color wheel than palettes I will add a state saving to this popup.
  • Few questions about stroke arrows
    @VectorStyler said in Few questions about stroke arrows: Yes, there is a need for a starting size relative to the stroke width. Scan be further adjusted with scale. Yes, the arrow shape is combined with the stroke. That's absolutely fine! just good to know. I could combine the name with the description for the tooltip. No need for that. I see that if you leave description empty it just shows the name. That's fine. Doesn't change the fact that I don't see the purpose or ease of use of 'description'. Available only if the arrow shape is an open path OK. I personally find the 'grayed out' system more helpful if something is not available. Whether it concerns panels or menus. Then you at least know that the function is there but cannot be applied. Then you can experiment until the light comes on. Also no strange empty spaces or jumping rhythms in your layout. I tested this now and the preview sizes did not change here. For me they are also back to the old size after changing display mode and back. Thanks
  • a function request.
    @monsterfox Not directly with shape effects. It can support if mesh gradient is used (it is possible to do a mesh that looks as 1). The mesh gradient nodes are distorted by shape effect. The 4-point distortion shape effect has an image effect version also. Open the Image Effects panel and the [+] button has a Mesh menu with the 4-point effect in it. But these are heavier to render and to work with.
  • Can VS import/place a HEIC file?
    @Boldline HEIC is not supported. I will add this to the features backlog
  • Scaled stroke gets pseudo value
    29
    41k Views
    @VectorStyler said in Scaled stroke gets pseudo value: "convert to actual" Good name! If this becomes a reality in the future, we have ultimately found a solution that meets both needs
  • Gap Tool questions
    @VectorStyler said in Gap Tool questions: This tool is useful in adjusting a rectangular layout on a page (mostly a DTP tool). oh ok - that makes sense in that context
  • Constraign handle to previous segment angle
    @VectorStyler said in Constraign handle to previous segment angle: just drag the line, not from the node but from some location along the line Yes, but then you still have to push the other back
  • Z-position text cursor
    @Ayo yes, I will try to fix this.
