• Multiple deletes required to fully remove all selected nodes
    @Boldline Replicated the problem. It should be deleting also with that option disabled. Will be fixed ASAP.
  • Custom Palette and colour groups - how does this work?
    @syllie Not dropped, just requires a bit more thinking But it is working now, as expected except the preview in the Output column.
  • How do I … ?
    View „Enable snapping“ was selected. Now I found the on/off switch. Many thanks!
  • "Quick Look" on Mac
    @Boldline 268.5 MB is not the universal. I will test this again if to find out what is going on.
  • Unlimited Undo's
    Welcome to VectorStyler! I don't see a way to setup unlimited undo, but you can change the undo steps here in Document Setup (Cmd-Shift-P): [image: 1682899441819-screenshot-2023-05-01-at-03.02.08.png] Also: the History panel (Ctrl-H) has an Undo/Redo slider.
  • Why does this shape lose integrity?
    syllieS
    @VectorStyler At the time I was just playing with the functionality and I posted it as question as it did not even occur to me it was unexpected behaviour. As such, I did not keep the original shape that I worked with to create my variation. I must have hit some extreme or applied an effect twice perhaps, as you can see in the shape, the petals are sort of heart shaped (indents are alternating). I do not even have a clue how to replicate the base shape. I did play a bit with the functions option too (S-Curve, Hanning, Sphere, Pinch). Not sure if this is worth pursuing. I now know that my nodes were not cusp, and I know how to correct this issue if it occurs. [image: 1682369530059-62e9771c-448c-4d38-9b7f-f7632fca7d92-image.png]
  • Shapebuilder question
    syllieS
    @VectorStyler I've sent you the file. I read that you were working on an overhaul. Thanks.
  • Path Sketch Tool extract from closed shape not working?
    @VectorStyler If the 'Exclude' boolean operation was named 'Subtract', 'Subtract' would be used here as well, and there would be no confusion about the meaning ('Exclude' can be misinterpreted).
  • Easiest way to do "Pucker" effect in VS?
    @syllie your welcome, indeed VS offers some playground to have fun . . btw related to corners @VectorStyler made already a video how to edit your own corner here the video with some corner magic . . I create a Tutorial a while ago, which shows a bit the power of smart shapes for pattern making Here the link: https://www.vectorstyler.com/forum/topic/2142/the-shape-of-things-using-parametric-shapes-for-pattern-making
  • How to Deselect in node tool?
    @Raven I think this could be a bug with the Deselect command. Will be fixed ASAP.
  • Trace of line drawings
    @syllie thank a lot for taking the time these are really helpful videos
  • Non modal Panels ?
    @VectorStyler said in Non modal Panels ?: In some cases this might be possible to implement. i would consider this as a long term thing even though I find this very useful and I guess that it also affects only a few panels Edited: One more thought came to mind. If we had a scripting language in VS, these things could perhaps be solved in this way.
  • Drag Object to Scroll
    Neil
  • Workspace Locking ?
    @b77 said in Workspace Locking ?: (You didn't use the search field under the Help menu? ) I did, but I wasn't looking for the word 'panel', I was looking for workspace Neil
  • Any way to move 2 selected anchor points in opposite direction?
    @syllie said in Any way to move 2 selected anchor points in opposite direction?: Step wise interactive change would have been nice I added this to the feature request backlog.
  • How did I create this 2nd artboard?
    @syllie said in How did I create this 2nd artboard?: Select artwork + RMB click with artboard tool creates a new artboard This part could be a bug. Will be fixed ASAP.
  • Magic Wand Selection & composite shape
    @syllie Can be replicated. This seems to be a bug, will be fixed ASAP.
  • Cannot assign shortcut for Select -> Select Similar -> Fill Color ?
    @syllie Yes, those are not separate actions. I will try to improve this for 1.2
    @syllie Yes, it is in the backlog and not yet implemented.
  • Auto-snapping a shape to 90 degrees keeps shape from being rotated freely
    @VectorStyler ok no problem. Thanks for the explanation. I'm glad this is fixed and improved upon already for a future update. Sounds like it will be a real game-changer when it's officially released. I can make do for now until then.
