  • Could we add more options for editing/removing select artboards ?
    In relation to this: Selecting a single Artboard in the list view of the Canvas panel -> invokes a "Zoom to Artboard" Could this be optional - or work only in combination with a modifier key? I would expect the zoom level to remain. If I select Artboards for rearrangement in the list, bulk formatting or deletion, I don't want a Zoom to an "arbitrary" Artboard. Selecting Artboard(s) in the list view should highlight a selection marquee around corresponding Artboard(s) - at least if the Artboard Tool is active. And vise-versa; selecting Artboards on the Canvas should update Artboard lines in the list view. Drag-moving an Artboard in the list to a different Canvas, then undo-ing will kill/disappear the Artboard. /BR Lars Herold 1.2.086 Mac+Win
  • Keep Original for Offset Path Tool
    1k Views
    @Subpath thank you, I will try that
  • Transform mode for nodes manipulations
    @VectorStyler that is so logical that I completely missed it. That's really great ! Thank you
    @Daniel said in New "Quick pen tool" in Illustrator beta form seems to have features that tie in with potential arc tool in VS: Edit: I see it has become a subscription-based project now. $7 per year is still not much. Maybe I remembered wrong that it was free. Looks like the Mac and PC and Linux are still one purchase and web version is a subscription.
  • Few Ideas to make the Object Role assignment more user-friendly
    @VectorStyler If the first suggestion isn't so easy to implement, I have no problem with it not being implemented. It was just a suggestion, and a nice-to-have. Regarding the second suggestion: I would definitely like a click in the scroll bar to scroll a page forward e.g backward. page. Of course, I'll leave any other additional implementations up to you.
    @Boldline I added this to the backlog
  • Cylinder Warp Option Request
  • Random selection
    @Li-Xiao thanks for the video ! That's funny, my next YT tutorial is about colorizer function and I'm also going to demonstrate the region coloring mode, which I like the best. I like the trick about clipping the image to adjust zoom and pan of reference image, that is smart.
  • EFFECT WHITE NOISE with more parameters as defocus
    @ZATOPEK said in EFFECT WHITE NOISE with more parameters as defocus: defocus & size parameters Can you show some examples how this would look like?
    @Boldline Maybe after 1.3
  • Reverse Transformation
    @VectorStyler No, the figures here are not symmetric
  • EXR multilayers EXPORT 32 bit float with preview
    ZATOPEKZ
    At your choice your layers can be saved in your export EXR multilayer or yours differents artboards can be saved in your EXR multilayer
  • 'Recently added fonts' category
    @encart said in 'Recently added fonts' category: Alternatively, sort them by creation/added date. I have to check if the added date info is available. But sorting by file date would be easy.
  • Would a style picker for multiple objects be possible?
    @Boldline , @syllie and anyone who is interested The Tutorial is finish you found it here. https://www.vectorstyler.com/forum/topic/5406/kind-of-guilloche-pattern
  • Export preview
    @MrDixioner Maybe after 1.3 it can be added
    1k Views
    @VectorStyler As I already wrote, just ignore my request. I'll create an action, just like Monsterfox suggested. I dont know if my idea was so well thought. Because a ninth Alignment Icon would create a mess in the Alignment panel. But my idea was to combine these two in a addional icon. [image: 1760688003900-center-alignment.png] Currently, two clicks are always required to center objects horizontally and vertically, something that would normally require just one click and is used very often. But forget it. I'll use an action, and that'll be fine for me.
  • Is there a way to set these text boxes more permanently?
    1k Views
    @VectorStyler It would be nice to have the individual links to the files remain but add that extra option to the list to "export debug report" if it helps, when you're ready, I can generate a debug report from Eagle and send the zip to you. You could see the kinds of things they have included, etc.
  • - Resume Selection
    1k Views
    @monsterfox I will try to add this
