  • Split Node Selection tool into two-select nodes and convert to Bezier
    Well, I guess if you're overloaded with options and features, that would justify breaking that one tool into several, each of which doing a subset of the functions of the original one. If I classified the behavior I know of that that tool has, in order of most benign to most powerful, it would be: Node selection Translation of selected nodes Translation of segments bounded by selected nodes by selecting segment directly Conversion of straight segments to Bezier curves Deforming Bezier curves (unknown algorithm) The first two classes could be combined into one tool (I think this is Illustrator's white arrow funcitonality) The third should be a class in itself. Converting a data type is very different than selecting and translation. May not be invertible. The fourth is available in Illustrator's white arrow-sort of. In Illustrator's, the slope of the Bezier control points that are not on the curve remains constant. It simply extends or shrinks them. This is very important because you usually know the slope at the end point of a curve. Dragging the curve with that constraint is really valuable. I'm not sure what your algorithm is, but decoupling the terminal slopes from the curve translation allows you to (1) put down the curve with slopes where you know them and (2) optimally fit the curve with these boundary conditions to, say a curve in an image. That functionality could be put in the node selection tool if you divided off the datatype conversion to a separate tool.
  • Additional way of random "For Each" rotations in fixed Steps
    @Subpath I added this to the backlog
  • Magic Wand selection based on size
    @EricP said in Magic Wand selection based on size: is there a way to achieve this or could that be a feature enhancement ? Not possible for now, I added this to the features backlog.
  • Improve Node Bump Effect
    @Subpath It seems our opinions are highly unified. His ability to use VS far surpasses most people. We need to keep up the good work.
  • parameter fine-tuning
  • New transformation tool
    @monsterfox I think the snapping is missing from this tool, I have to check that. Curving is normal once you move a point, but it can be disabled if you open the Shape Effects panel and open the Elastic Warp options.
  • Dedicated automated export panel for different child images
    @Boldline The "Panels -> Editing -> Object Export" should be similar.
  • stroke width
    @VectorStyler [image: 1748774475454-mmexport1748774254694-resized.png] Can we add a function similar to the Outline effect in the panel?
  • Polygonal Spiral needs to add rotate parameters
    @VectorStyler Looking forward to the upcoming 1.3 version, thank you very much!
  • Draw circles/arcs from central point
    @Usuario Some shape properties can be manually entered in the Shape panel. For example to set the circle and polygon radius to the same value. Also: alignment might not help in this case, but using Collision snapping could place the polygon to the right position (if its radius is the same as the circle).
  • Set control key modifier to act as right-click on mouse?
    @Boldline This should work with the Option key.
  • Adding 'New document' button at the end of tabs with open files.
    6 Votes
    @encart I added this to the backlog.
  • Unlock Last Locked
    @Boldline I added this to the features backlog.
  • create a Discord channel
    @VectorStyler well
  • The new magic wand selection
    @VectorStyler The following error is included in the file I provided. Selecting the red circle inside will result in the selection of the outer graphic.
  • Ideas for improving the color palette
    @Subpath I added this to the backlog.
  • Shape picker options
    @monsterfox I added this to the backlog
  • User defined Steps for Blends that persist even after restartin VS
  • About the imperfection in path blending"
    @monsterfox said in About the imperfection in path blending": Could you add a dedicated centerline blending mode? I will try this if possible (later)
  • Curvature tool
    26
    38k Views
    @Daniel You've done an awesome job discussing the tools, the Bezigon tool especially! I've learned a ton of information from you on all this and I appreciate your dedication to helping everyone understand better. I'm sure @VectorStyler has a good sense of what you're talking about and when he gets the opportunity to add it, we can go deeper with it and see if there are improvements to be made, etc.
