  • EFFECT WHITE NOISE with more parameters as defocus
    @ZATOPEK said in EFFECT WHITE NOISE with more parameters as defocus: defocus & size parameters Can you show some examples how this would look like?
    @Boldline Maybe after 1.3
  • Reverse Transformation
    @VectorStyler No, the figures here are not symmetric
  • EXR multilayers EXPORT 32 bit float with preview
    ZATOPEKZ
    At your choice your layers can be saved in your export EXR multilayer or yours differents artboards can be saved in your EXR multilayer
  • 'Recently added fonts' category
    @encart said in 'Recently added fonts' category: Alternatively, sort them by creation/added date. I have to check if the added date info is available. But sorting by file date would be easy.
  • Would a style picker for multiple objects be possible?
    @Boldline , @syllie and anyone who is interested The Tutorial is finish you found it here. https://www.vectorstyler.com/forum/topic/5406/kind-of-guilloche-pattern
  • Export preview
    @MrDixioner Maybe after 1.3 it can be added
    1k Views
    @VectorStyler As I already wrote, just ignore my request. I'll create an action, just like Monsterfox suggested. I dont know if my idea was so well thought. Because a ninth Alignment Icon would create a mess in the Alignment panel. But my idea was to combine these two in a addional icon. [image: 1760688003900-center-alignment.png] Currently, two clicks are always required to center objects horizontally and vertically, something that would normally require just one click and is used very often. But forget it. I'll use an action, and that'll be fine for me.
  • Is there a way to set these text boxes more permanently?
    1k Views
    @VectorStyler It would be nice to have the individual links to the files remain but add that extra option to the list to "export debug report" if it helps, when you're ready, I can generate a debug report from Eagle and send the zip to you. You could see the kinds of things they have included, etc.
  • - Resume Selection
    1k Views
    @monsterfox I will try to add this
  • Request a Live Mirror / Real-Time Symmetry Drawing feature in VectorStyler.
    @VectorStyler nice
  • Parallel drawing
    @monsterfox This can be done with offset path (after drawing).
  • Link Shapes
    @monsterfox This will need some clarification (later)
  • Modify Gradient Numbers with Keyboard
    1k Views
    @Albaris I added this to the backlog. Currently this is possible with the gradient tool (from the toolbox), if you double click a color knob.
  • Add the option/alt key modifier to the Repeat action tool
    @Albaris said in Add the option/alt key modifier to the Repeat action tool: For example, if I switch between the node tool (A) and Shift + C (anchor point), it deselects, I will try to replicate and fix this.
  • Toggle option for Paste Keeps position
    @Harry thanks - yes that is another way to accomplish it but I'm more referring to situations where you have an object on a different part of the canvas and want to paste a copy of it on a very different part of the canvas. It doesn't make sense in that situation to make a copy and then have to literally drag it over there to use. I like the option in settings to decide if you want it to default to pasting in place, but the ability to use a modifier to get the opposite would be helpful.
  • Option to Auto-locate workspace file?
    1k Views
    @Boldline I added this to the backlog
  • Add non-brush divider options to subdivide brush groups?
    @Boldline I will try to implement this.
  • Option to change the a setting on multiple brushes?
    1k Views
    @Boldline This is not possible for now in VS, you have to change then individually. I will think of a solution, but maybe after 1.3
  • Appearance panel behaviour
    The Appearance panel is now working as expected. Thank you!
