  • Improved logic in Symbols stamp / brush
    @VectorStyler https://gitlab.com/inkscape/inkscape/-/merge_requests/5375 You can refer to this.
  • Selected Color Palette Prompt
    DanielD
    @Daniel: Inkscape nicked a lot of ideas from Xara and Corel. Corel nicked ideas from Xara. Xara is the original gangster in the gang.
  • Improvements for "Replace Color" panel
    @VectorStyler thanks! Also, sometimes when I am selecting colors on the left side, VS does not always let me select them - they don't always get highlighted, I think in part because some might have multiple colors inside the grouping? Would it make sense to add a button on the left side of the colors that could be clicked on or off to highlight the color?
  • Addition to the Color pallete panel
    @VectorStyler thanks for the quick implementation
  • Right-click Function Extension
    @VectorStyler Eager to witness your brainstorm brilliance!"
  • Auto-closed path
    @monsterfox said in Auto-closed path: When the two ends of a path are close to each other, a single connect operation can merge them into one, forming a closed path. A button for this is available in the context panel when the Node tool is active. Dragging one end of a path to touch the other end should automatically close the path. We'd like to add this functionality. I'm not sure about this automatically.
  • incremental spacing feature
    @VectorStyler This is similar to the curve-based operation I mentioned earlier, but it lacks precise control. It would be perfect if we could have parametric settings.
  • Shift modifier to keep end nodes stationary
    @Boldline said in Shift modifier to keep end nodes stationary: I was testing this out in VS but could not quite tell if it was implemented or not. This is not supported in VS.
  • Could the Polygon Tool start with the last Setting used ?
    @VectorStyler said in Could the Polygon Tool start with the last Setting used ?: For the default options, click on the canvas with the polygon tool (no dragging) Thank you, i test it and it works this way
  • adding animation features
    @lilith said in adding animation features: Will you consider adding animation features in the future, such as Synfig Studio Maybe in a spin-off app. The current VS is already very complex, and there is a lot that will be added.
  • Slightly snapping of Sliders on Zero / Neutral Position
    @VectorStyler Here is a picture of what I meant [image: 1742544339652-neutral-position.png]
    @Daniel I added these to the features backlog.
    @VectorStyler said in Could context bar show color and stroke and fill information for the pen tool when the pen tool is selected?: I can add this to the next build. That would be nice because there is something to be said for BL's idea if you make the analogy with the real world. After all, you first take the pencil of the right color before you start drawing.
  • Colors Bucket Fill tool
    @FastVector I added this to the backlog.
  • Smart Transform
    DanielD
    Ah! Brilliant. Thanks @VectorStyler!
  • User defined Color for Shape Builder
    @Boldline said in User defined Color for Shape Builder: @Subpath I understand what you are suggesting. It would make sense to me if the setting is where you were suggesting it be - in the shape builder panel and not in the overall setting since it seems pretty busy there I agree, the Shape Builder panel would be the most logical place for me too for such a setting
  • Print Interface Optimization
    @monsterfox I will try to find a better layout for this.
  • Please replicate FreeHand Find & Replace function in VS
    DanielD
    No rush. Take your time. I'd rather you implement it correctly than rush out something that is broken and buggy. We already have affinity for that. By the way, this has been a pending request to Affinity since, wait for it, 2015. That's ten years. Hopefully you don't need a decade.
