  • Feature Request: Pressure-Controlled Opacity for Calligraphic Drawing
    @Usuario Hi, I don't know if you'd only use vector graphics for your kanji writing. There can of course be several reasons for this. Anyway, wanted to draw your attention to an app. That may interest you. Don't know if you already know it. This app tries to imitate Chinese watercolors and brushes. It's called "Expresii." Here's a link. https://www.expresii.com/
  • Ability to change spacing height and width at same time in repeater
    1k Views
    @Boldline I added this to the backlog, but not sure if it can make it into 1.3
    @Subpath @VectorStyler OK thank you. that makes more sense. Maybe I was confused because the option for transparent was there automatically when i started editing the settings under bmp.
  • auto-snap-to-collision
    @VectorStyler Yes, there are still some issues with the collision effect at the moment. I look forward to you demonstrating a better version for me first.
  • Noise/Randomize Effect for the Blend Option Tools
    @VectorStyler , thank you
  • Apply number variable to color parameters
    @VectorStyler thanks I need to explore the color scheme panel more, but It seems to apply a single color to all selected objects. I'm looking for ways to vary colors across objects using different patterns. I think colorize effect is more suited for this. I have to understand how the variations work in colorize effect. I do not always get the expected results, maybe by misunderstanding how the feature is supposed to work
  • Snap to Self option
    @jpsimmons Also in the context panel: [image: 1755286522779-context.png]
  • Advocating for a built-in mirror option
    @Boldline i made a video about a workaround in VS to simulate a kind of Mirror / Symmetrie Tool which may be helpful in the meantime you could look here: https://www.vectorstyler.com/forum/topic/5313/symmetrie-tool-feature-workaround
  • New Magic Wand function
    @monsterfox said in New Magic Wand function: @VectorStyler By the way, what percentage of version 1.3 has been completed? And roughly how long will it take to release? I will try to have 1.3 out by end of November. Most important large features are done, but some smaller ones missing still
    @VectorStyler thank you! I had written to Eagle as well and I forwarded you my initial email and their response in case it helps us figure out what causes the issues in VS export of the SVG files
  • Union each group of objects
    @encart Before dedicated functionality is available, using Split Object should quickly address this issue. I have recorded a video for reference. https://youtu.be/Ahwv-3wKwQo
  • "Apply on selection" also in other panels
    @VectorStyler My mistake, I'm sorry. I was unintentionally setting the "fill" color instead of the "outline color". I apologize.
  • Draw multiple line from a node
    @Jayanta-Das said in Draw multiple line from a node: Requesting for a feature where we can draw multiple line from a node. Yes, this is in the backlog, but not sure if can be done by 1.3
  • Option to Show Individual Object Handles Within Group Selections
    @VectorStyler Good enough. You basically want to reach parity with Illustrator with functionality. This is a noticeable friction point.
  • Fit Text Frame option should follow the pivot point set by user
    1k Views
    @Raaskot I added this to the backlog
  • VS favors large objects over smaller ones when selecting
    @VectorStyler thanks. zoom level seems to make a big difference. The farther I am zoomed out from the objects I am attempting to select, the harder it is to select a small object. I instinctively have to zoom farther in to get VS to choose the smaller object first. I'll create an example I can send to test this
  • Region Path Combine respecting blend modes
    @VectorStyler oh that's really great !! so much hidden functionality to be discovered Thanks !
    @VectorStyler I think that would be ok though. maybe the first live text box selected is the one that all other selected live text boxes use as reference for size and position?
  • Colorize Blend Mode
    1k Views
    @EricP I added this to the backlog.
