      Mirroring / Flip does not work as expected
      @vectoradmin Hi Just like to say, that with the latest Update 1.0.057 everthing works fine now.
      Line Shape Grid issues
      @vectoradmin Hmmm I does seem a little redundant that the controls in the line shape grid and other shapes available on the vertical toolbar are basically offered as well in the shape panel. Now that I understand how it functions, I'm not as bothered by the preview and controls available in the line shape grid and other shapes panels available by double clicking in the vertical toolbar Maybe worth just leaving alone for now?
      Update not installing (Mac)
      @vectoradmin - thanks, manual installation has worked fine!
    • C
      Font not rendering
      C
      In the meantime I converted some of my old fonts with the app TransType 4. I recommend if anybody else has this problem and find it difficult to get updated original fonts.
      do not open layer when duplicating in layers panel.
      @Boldline The duplication (with buttons) should keep the layer / group closed in build 1.0.055
    • encartE
      Split text feature does not work.
      @encart @Boldline @b77 The split text issues are fixed in build 1.0.055
    • encartE
      [Clipping Group] Issues with Intersect/Expand ; An Object inside the group changes position when main shape is conveted to curves.
      @encart These issues are fixed in build 1.0.055
    • encartE
      App crashing whenever I want to activate a custom toolbox
      @encart @Boldline Toolbox customization has been improved in build 1.0.055
      Some panels are not responsive
      @KF There are some fixes regarding panel management regressions, in build 1.0.055
    • encartE
      [Pencil Tool - rope stabilizer] The line does not end at the end of the rope depending on the zoom
      @encart This should be fixed in build 1.0.055
    • encartE
      [Application Shortcuts ] Label for Undo shortcut changes depending on the last operation.
    • encartE
      Redo Button is grayed out / inactive.
    • encartE
      White Squares instead of Glyphs popup previews
      Not seeing line attributes
      @Jono The guide rendering bug should be fixed in build 1.0.055
      panels regression
      @Boldline This regression is fixed in build 1.0.055
      Eraser function for Pencil tool broken
      @postdes This regression should be fixed in build 1.0.055
    • encartE
      [Transform Panel] Width units changing from mm to meters
      @encart At the first click, the whole field should be highlighted, and typing should erase all. Is this working? The problem with partial deletion is that it should be possible and allowed, and that includes ending up from mm to m.
      Screen not rendering consistently for some zoom levels
      Same here, every thing seems fine, since Version 1.0.054
      Crash Report Misspelling
      @Boldline Will be fixed.
    • encartE
      [Path drawing] The first point's handles position change toward the second .
      Thank you. It's fixed.
