    • encartE
      Preferences > Adjustments > Tracking change begins from 10%
      @encart Fixed in build 1.0.048
    • C
      Drag-scaling text element does not change displayed point size
      22k Views
      @Gremriel This should be fixed in build 1.0.048.
    • encartE
      [Path drawing] Problem with closing a path . Endpoints do not merge into one.
      @encart The end point should now snap to the starting point if close in build 1.0.048
      VS loses paste function when attempting to paste vector from Illustrator CS2
      @Boldline The exported (for clipboard) PDF version is now set to 1.6 (was 1.7 before). This should work with CS2. Let me know if there are still issues.
      imported images have two strange lines in them
      Watching Ignoring Scheduled Pinned Locked Moved imported images
      @Boldline Pasting images from the clipboard had some (replicated) issues. These have been fixed in the new build 1.0.048
      Merge Boolean not always Working
      @Boldline There were improvements to Merge boolean in the new build (1.0.048). I will close this topic and lets open an other one if new issues are encountered.
    • V
      Offset Path and Offset Path "Effects" Scrolling not Working in some Entry Fields; Boundary Offset Issues
      @Vector-Rock There have been improvements to the Offset Path, and the other reported issues in the original post (build 1.0.048).
    • V
      Offset Path Inaccuracies. Gap in Stroked Offset.
      @Vector-Rock There has been improvements in the Offset Path. I will close this now, and lets open a new topic with new issues when found.
      Flickering canvas on M1
      20k Views
      @Kyriakos @encart Can the flickering issue be replicated? There is a double buffering enabled for all display types now.
      Copying and pasting from one layer to another does not copy all of selection
      @Boldline There has been fixes to the pasteboard recently. I cannot replicate this issue in build 1.0.048, and I will close it for now. if there are further pasteboard issues, we can open a new topic.
      Bug? Swatches stay highlighted without an assignment or object selection
      @Arde This should work in as requested in the latest version.
    • V
      Artifacts created in Offset Path, Offset Path Effect...with larger values
      @Vector-Rock The Offset Path has been improved in recent builds (1.0.048), I will close this issue and open a new one as new issues are discovered.
      Wrong font shown for selected vector shape texts
      @Arde This issue should be fixed in build 1.0.048
      Outer stroke seems to be broken
      @vectoradmin Stroke alignment (and offset path) has been improved in the new build 1.0.048. I will close this issue, and open one when new issues are found.
    • encartE
      Ability to change color and stroke when creating an Offset Path
      @vectoradmin I followed all your directions. Unfortunately, no changes.
      Selecting color can only be done in steps, unless the color selector palette is undocked (Windows)
      Hi, Ok, I understand. It seems that by lowering the drag speed allows me to select a color that is closer to where the 'dot' was when I clicked on it.
    • 861475_VctSt8
      Failure to switch from the Text tool (T) to other tools
      @vectoradmin Thanks. I have confirmed that it is fixed. Comfortable to work with.
      Typing a Comma while within a text box brings up split view
      @Boldline Fixed in build 1.0.046
      Are there two Style buttons in the text context menu bar?
      Issues with effects applied
      @gentlecl Fixed in build 1.0.046
