      Language option isn't shown on Windows
      @vectoradmin I see, thank you.
      Custom pref file casing issue when installed on different computer
      @vectoradmin Thanks for getting back to me. That solved the problem! thanks again
      Save icon not changing color
      Yeah, keeps whistling until you press the Save button. (I hope the developer doesn't take us seriously on this one… )
    • ambrosA
      Zoom in / out doesn't work with more than one artboard
      ambrosA
      Yes it does !! That's actually pretty cool. A nice workflow. As far as I am concerned problem solved - i just didn't know the correct methodology
    • 861475_VctSt8
      Contextual Menu Afterimage
      @vectoradmin (1.0.062) Thank you. I've confirmed that it's fixed.
      Can't create group in Color Palette
      @vectoradmin Hello, Thank you. Now more option for users to store the color collection. Best regards, KF
      Open documents not reopening when restarting
      Just tested - works great. Thanks
      Text disappearing at some zoom levels
      Wow that was quick. Just tried it, perfect thanks
    • encartE
      [Text editor] Disappearing undeline
      @encart This should be fixed in build 1.0.062
      Path Brush clears vector shape being added to
      @Boldline This should be fixed in build 1.0.062
      Info panel too many digits in the timer?
      Swapping colors between fill and stroke in color panel turns both to empty fill and stroke
      Double and Triple Flag Warp Both Appear to be Broken
      Path Brush tool not leaving any results on screen
      Slider in Shape line tool (also in Shape panel) does not work
      Mislabel in Rectangle Panel hover text
      Alignment panel pulldown still reverts to "align to selection" after closing
      Spell check and default language
      @Jono The spell checker has been improved in build 1.0.062 The "spelling" language of a character style must be set in the Typography section of Character Options.
      Ligatures do not work with OpenType TT flavor (Windows)
      @Arde Ligrature handling has been improved in build 1.0.062
      Transform tool changes to skew mode on large files
      @William-Kansepa This issue was replicated, and it is fixed now in build 1.0.062
