    Little indicator Sign "°" for Path Sketch Tool to know that a Shape is closed
    40 Posts 5 Posters 82.9k Views 4 Watching
      Here we have Affinity which shows all its pointer symbols in action, there are probably too many and you like to verify by checking the help in the status bar.
      alt text
      In Affinity this symbol means "Start on new curve" while a small circle means close curve. I guess that's what it also means in Xara. It's Xara that Serif seems to be in British competition with more than anyone.
      But all in all, the symbol richness starts to necessitate the status bar.
        Subpath @Ingolf
        @Ingolf
        Do not really understand the cause of the circle
        symbol on Pencil Tool. It doesnt show me if the
        Shape is close or the Nodes are just close togther.
        But i would like to have a visuell Notice that a Shape
        is closed. That only appears if a shape is closed.
        It doesnt matter also to me which symbol is used
        as a indicator.
          Ingolf @Subpath
          @Subpath said in Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed:
          @Ingolf
          The circle means that the action will close the shape. As is the case in Affinity. Whether or not a finished shape is closed or not from there should be communicated in a status bar or elsewhere, not in the pointer.
            Subpath @Ingolf
            @Ingolf said in Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed:
            In xara it is just a Indicator if a shape is closed
            with the Pen sketch tool. As the Video shows.
            There is also a little "~" sign when you cut something with the
            Sketch tool in xara.
            But as Xara cuttin is different from VS
            this "~" is not needed
              Subpath @Ingolf
              sorry did not find this practical.
              As i Paint i look on the Tool i paint with
              and not on the Status bar. I need a few eyes
              more to do that.
                Ah, I have most programs, Xara including (just to try it, never using it, mistake) and they are partly on the wrong track.
                • in Xara means " draw on from this node" but also "close shape" which is misleading. A circle here or some other symbol should show "hereby you close your shape".
                alt text
                I don't buy bad usability. Neither from Xara, despite their 500 attempts to extend the subscription of their oldware.
                  b77 @Subpath
                  @Subpath OK, but in Xara the '+' sign is displayed on the cursor, right?
                  If a sign would be displayed where the shape gets closed (over that closing node) it would make more sense.
                  And since VS already displays a circle when you close a shape with the Pen tool, the same circle could be displayed over the node when a shape gets closed with the Path Sketch tool.
                  This is what Ingolf is saying, if I'm not mistaken.
                    Ingolf @Subpath
                    @Subpath said in [Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed]
                    As i Paint i look on the Tool i paint with and not on the Status bar. I need a few eyes more to do that.
                    True, but bad design is over-communicating, and since a shape can easily be open on purpose, that's secondary information.
                      Subpath @VectorStyler
                      @VectorStyler said in Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed:
                      @Subpath Would this also be needed in the Pencil tool?
                      Had actually only thought of the Path Sketch tool. Because there often times a shape
                      was not closed.
                      If it would also be helpful with the Pencil Tool why not.
                      Basically I just missed some kind of indicator that would show you that a Shape is closed,
                      so that you don't have to try it out first.
                        Ingolf @Subpath
                        @VectorStyler said in [Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed]
                        Because the tool symbols signal an action, not a state of something else.
                          Subpath @b77
                          It doesn't matter that much to me which icon is ultimately
                          used as an indicator.
                          The "+" symbol was just an example of an indicator.
                          And the small circle on the Pencil Tool would make more sense to me if it appears
                          at the moment a shape is closed or shortly before.
                            b77 @Subpath
                            @Subpath OK, got the part about '+' being used just as an example. 👍
                            But with the Path Sketch tool I see no use in adding a sign to its cursor when it gets close to intersecting or self-intersecting.
                            I do like to see an indicator over the closing node itself and after it's been closed.
                            And it's the same with the Pencil tool, I would say.
                              For your Eyes also 🙂
                              It doesnt matter to me which Symbol for this Indicator
                              would be used. That "+" Sign was just an Example.
                              And two questions
                              Should the small circle at the pencil symbol represent a snap radius.
                              If this were so you could we adjust this snap radius
                              (larger/smaller) ?
                              A thought of mine was that this circle should maybe only appear
                              when a shape is about to be closed.
                              ( corelated with the snap radius)
                                Subpath @b77
                                @b77 said in Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed:
                                Do not really understand what do you mean with that.
                                The Reason for my Request was, when that i draw with Path Sketch Tool
                                and would like to get a closed Shape, i often missed the Point where the Shape is closed.
                                Is often a kind of trial and error.
                                So i though of an Indicator as a help.
                                And as i saw the little Circle on the Pencil Tool
                                i though a kind of a snap radius (adjustable)
                                could also be nice
                                  b77 @Subpath
                                  could also be nice
                                  So when the path you draw gets real close to the other endpoint, the app should auto-nudge the last node over the other and close the shape?
                                  IngolfI S 2 Replies Last reply Reply Quote 0
                                    Ingolf @b77
                                    This is how it works in the pen tool in Vecstorstyler. Is it not what you need? With a possible option whether or not it should snap and at what distance?
                                    (The yellow circle indicates my clicks, that is from the GIF software)
                                    Pen GIF
                                      @Ingolf
                                      Is, in my eyes, not comparable with the Pen Tool.
                                      Because when you draw with the Path Sketch or the Pencil tool
                                      you often draw a little faster. So you need a somewhat bigger snap radius.
                                      I don't know what speaks against an (adjustable) snap radius.
                                      Made a Pic where the Circle is the double Size of the Circle
                                      used by now, but could also be a little smaller.
                                      So i think an adjust option would be nice.
                                        Subpath @b77
                                        in principle, yes
                                        this is the extended version of my original idea.
                                        Originally I just wanted an indicator that a Shape is closed.
                                        b77B 2 Replies Last reply Reply Quote 1
                                          Ingolf @Subpath
                                          @Ingolf
                                          I requested it in the pen tool so I understand now and agree. A "Snap when closing" (with better tooltip) and a snap radius setting in a context sensitive toolbar would make perfect sense to me. Even shorter label would be fine.
                                            b77 @Subpath
                                            @Subpath Nothing against a 'close' indicator and snap radius either. 👍
                                            It's just that your first screen capture from Xara showed the indicator on the cursor, not on the shape where it should be IMO.
