Little indicator Sign "°" for Path Sketch Tool to know that a Shape is closed
@Subpath said in [Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed]
As i Paint i look on the Tool i paint with and not on the Status bar. I need a few eyes more to do that.
True, but bad design is over-communicating, and since a shape can easily be open on purpose, that's secondary information.
@VectorStyler said in Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed:
@Subpath Would this also be needed in the Pencil tool?
Had actually only thought of the Path Sketch tool. Because there often times a shape
was not closed.If it would also be helpful with the Pencil Tool why not.
Basically I just missed some kind of indicator that would show you that a Shape is closed,
so that you don't have to try it out first. -
@Subpath said in Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed:
@VectorStyler said in [Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed]
If it would also be helpful with the Pencil Tool why not.Because the tool symbols signal an action, not a state of something else.
It doesn't matter that much to me which icon is ultimately
used as an indicator.
The "+" symbol was just an example of an indicator.And the small circle on the Pencil Tool would make more sense to me if it appears
at the moment a shape is closed or shortly before. -
@Subpath OK, got the part about '+' being used just as an example.
But with the Path Sketch tool I see no use in adding a sign to its cursor when it gets close to intersecting or self-intersecting.
I do like to see an indicator over the closing node itself and after it's been closed.
And it's the same with the Pencil tool, I would say.
For your Eyes also
It doesnt matter to me which Symbol for this Indicator
would be used. That "+" Sign was just an Example.And two questions
Should the small circle at the pencil symbol represent a snap radius.
If this were so you could we adjust this snap radius
(larger/smaller) ?2
A thought of mine was that this circle should maybe only appear
when a shape is about to be closed.
( corelated with the snap radius) -
@b77 said in Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed:
Do not really understand what do you mean with that.
The Reason for my Request was, when that i draw with Path Sketch Tool
and would like to get a closed Shape, i often missed the Point where the Shape is closed.
Is often a kind of trial and error.So i though of an Indicator as a help.
And as i saw the little Circle on the Pencil Tool
i though a kind of a snap radius (adjustable)
could also be nice -
could also be niceSo when the path you draw gets real close to the other endpoint, the app should auto-nudge the last node over the other and close the shape?
This is how it works in the pen tool in Vecstorstyler. Is it not what you need? With a possible option whether or not it should snap and at what distance?
(The yellow circle indicates my clicks, that is from the GIF software)
Is, in my eyes, not comparable with the Pen Tool.
Because when you draw with the Path Sketch or the Pencil tool
you often draw a little faster. So you need a somewhat bigger snap radius.
I don't know what speaks against an (adjustable) snap radius.
Made a Pic where the Circle is the double Size of the Circle
used by now, but could also be a little smaller.
So i think an adjust option would be nice.
in principle, yes
this is the extended version of my original idea.Originally I just wanted an indicator that a Shape is closed.
So i think an adjust option would be nice.I requested it in the pen tool so I understand now and agree. A "Snap when closing" (with better tooltip) and a snap radius setting in a context sensitive toolbar would make perfect sense to me. Even shorter label would be fine.
@Subpath Nothing against a 'close' indicator and snap radius either.
It's just that your first screen capture from Xara showed the indicator on the cursor, not on the shape where it should be IMO. -
@Subpath Btw, the Path Sketch tool allows you to redraw the last stroke if you press Option/Alt.
interesting, could you tell me a little more in detail
how this work ? Could not figure it out by myself. -
@Subpath After you draw a stroke and it's not exactly what you want (let's say, it didn't intersect the object you wanted or it didn't self-intersect), hold down Option/Alt and draw it again.
It's just that your first screen capture from Xara showed the indicator on the cursor, not on the shape where it should be IMO.thats also often a fault of Recordit, it doesnt show
often the right positions of shapeswill use my other Gif Recorder "Screen to Gif" more often
(btw a really nice little Tool) but Win only -
@Subpath Oh… got it.
From my playing around with the Path Sketch tool, I am wondering if it really needs an indicator to close - the closed path erases away and an open path creates a fill - usually I am just making sure the path overlaps itself on the side opposite the fill
