    289 Topics
  • The issue of moving after removing transform
    @Li-Xiao Not really a bug, but it can be confusing. The problem is that the transform is on a group (with a single object content), and inside that group the object is moved. This transform then applies to the movement also, and removing the transform will make the movement much smaller. It is quite easy to create this scenario: create a group of 2 or more objects. transform the group (make it 2x larger). isolate the group and move one object away from the rest. select the group and remove the transform. the object that was moved further away will have some movement back. removing the other objects from the group, before removing the transform will make this "offset" more confusing.
  • Bug
    @monsterfox Yes, this was mentioned before with references and clones, but scaling and rotation of these are always centered. I have a task open for this (in the features backlog), and I will try to find a solution
  • Spelling error
    @Boldline Thanks for noticing. will be fixed in the next build.
  • 'Repeater', bug ?
    @B-Vs-V Set the Expand amount to 0 (this expands the shape), and enable the "Restrict Using Shape" option.
  • There is a crash issue with Repeater
    @VectorStyler Fixed. thanks
  • Invalid issue with the corner shape button
  • two bugs
    @Li-Xiao said in two bugs: There is indeed an issue with selecting the line mode Yes, this was the key. I will try to fix this as soon as possible.
  • Symbol
    @VectorStyler I haven't tried to reproduce the issue. As for moving the layers ,I can't see the blue destination line: it's not sufficiently marked (sorry for my terse sentence)
  • Coordinate start ikon a bit confusing
    @Raaskot Yes, this is indeed the case. The icon does not depend on the coordinate direction. I will think of a solution.
  • Old files & activated fonts with...
    @B-Vs-V said in Old files & activated fonts with...: an old design made with an earlier version is no longer correct (blending feature). yes, this might have happened with 1.2 (about a year ago), if the file is older. Send me an example and I will try to figure it out. I opened a bug with the Fondbase case. Are these TTF or Type1 fonts?
  • Graphic replacement error
    @VectorStyler [image: 1744971871472-dd3941ef-0146-4b7f-9d06-d939df2ce8e1-image.png]
  • Graphics without color information
    @monsterfox Yes, I think this was by design. If there are no attributes (fill or color) then it might be skipped when exporting. I have to check if it is possible to export these.
  • Unit of measurement
    @monsterfox If you previously typed a unit in some number editor, then that will be kept for that number editor. Also, some number fields default to specific units.
  • Issue with Contour
    Since I don't want to change the W display scaling, I have to wait for the fix to proceed further...
  • The handle can control the anchor point
    @monsterfox said in The handle can control the anchor point: Why does this happen sometimes but not always?" Could be the issue with the box selection. I will check that.
  • Appearance panel - colour symbol
    @B-Vs-V These should be in c:\Users<user name>\AppData\Roaming\NumericPath\VectorStyler1.2\vector\data\resources\ (the "Roaming" folder can also be "Local")
  • Appearance panel
    @VectorStyler I already sent you the file.
  • Bug
  • Path lengthening tool
    @monsterfox @Subpath I will try to improve this.
  • Symbol Stamp Tool / Symbol Spray Brush Bug
    @Harry I opened a bug on this.
