      Crash During PDF Export
      @VectorStyler Thanks Admin
    • IgullI
      Rename Layer Object using Object Options Panel
      @Igull said in Rename Layer Object using Object Options Panel: If the object is locked This must be the cause.
    • IgullI
      Internal Filename
      @VectorStyler OK, I'm sure there will be a reason for that It's not an issue. Neil
    • IgullI
      Inside Erase Bug
      @VectorStyler said in Inside Erase Bug: @Igull This issue should be fixed in build 1.1.080 Yes, definitely fixed, thanks ! Neil
    • encartE
      The imported SVG file is cluttered with unnecessary curves
      Yes, the problem does not occur. Thank you
      Tilling Pattern
      @Pat This issue should be fixed in build 1.1.080
    • encartE
      Alt+ Scroll wheel creates new obcjects while changing width/height value in Transform Panel
      @encart This issue should be fixed in build 1.1.080
      Wrong and to many colors in Image to color palette
      @Subpath This issue should be fixed in build 1.1.080
      Rectangle tool with stroke set to outside or inside causes issues
      @Boldline This issue should be fixed in build 1.1.080
      Create composite shape make program crash
      @mtinra This issue should be fixed in build 1.1.080
      Selected object lost when open edit color dialog
      Issue when switching from tablet to mouse
      @Pat I have made some changes to how the mouse/tablet switching is handled on Windows. But since I could not replicate the bug, I cannot be sure if these changes fix the issue. Please check if the problem occurs again.
      Vector Styler UI text and icons not scaled correctly in multiscreen/multi resolution environment
      @GraphicsGuy This issue should be fixed in build 1.1.080
      Fonts activated in FontBase doesn't work in VectorStyler
      @VectorStyler This issue should be fixed in build 1.1.080
      Repeater panel -> Repeater Geometry: flipping not functional
    • encartE
      Select all hidden/locked objects doesn't work in Layer Panel context menu
    • R
      Moving selected objects onto a target layer
    • IgullI
      Minor Menuitem Changes
      App Freezes If Words Get Deleted using Backspace
      @gotanidea This issue should be fixed in build 1.1.080
    • R
      Transform Move of multiple objects
      @Raven This issue should be fixed in build 1.1.080
