• Splash screen problems
    @encart Added this to the backlog.
  • Multiple object scaling together move opposite
    @Boldline Replicated here also. This one seems to be a regression from one of the recent builds. As a workaround: turn off the "Direct Shape Transformation" in Preferences -> Editing Options 2.
  • Selection Intersecting / Containing toggle
    @larsherold Found the bug, it affects the Selection panel only. The option is activated, but it is only taken into use after opening a document (or closing and reopening the current one).
    @Boldline I open a bug on this one.
  • Various units in Transform panel
    @Harry The only way for now is to just add a different unit name after the number, for example "10 pt" will set that field to use pt.
  • Circle: changing its shape with the Shape editor tool
    @Pat , thanks Well, I'm sitting at a 40-inch screen with 1440 x 900 pixels. I like large screens with a slightly lower resolution when I'm editing vector graphics. Find it better for the eyes because of the thin lines. Get along with the panels so far, except for a few exceptions.
  • Stylus creates extra rectangle selection box
  • seems to be a bug in VS 1.1.079 during the installation procedure
    @Subpath Got it. Similar issue has been also reported by others on Windows. I will try to replicate this.
  • Making a symbol, unexpected results
    @b77 @VectorStyler Thanks. I've always selected the whole object with the select&move tool and it worked so far. I tried to reproduce this problem. I selected and grouped and made sure everything was grouped. With the move tool, I can then duplicate it (Alt-drag) and move it. I activated 'Transform stroke' in the 'Object option' sub-menu, resize the whole object and made it a symbol (Object Role). It appears well in the symbol panel. I use it with the repeater function and the object ends up disappearing from the Symbol panel and from the large object I used to repeat it (Ctrl-R doesn't help). I will continue to test all these steps with a new file from the beginning.
    @Gremriel I will try to replicate this.
  • Impossible to reuse an old file with .078
    @b77 I could replace the file with yours and copying in VS is working fine Thanks.
  • 3 colour-related bugs
    @encart Send me an example file with the color issues. I will try to replicate it here.
  • The units in the Transform panel change according to position
    @encart I guess it happens after you delete just part of 'mm' (plus the number), so the app is left (or stuck) with 'm' to use instead?
  • Shape position in clipped text at wrong place
    @Subpath Looks like a bug, added it to the backlog.
  • Bug in 1.1.077 - Snapping icon is always inactive
    @VectorStyler said in Bug in 1.1.077 - Snapping icon is always inactive: @Ingolf The fix for this problem will be in the next build. Meanwhile, as a workaround: uncheck the "Active Item" checkbox for the folder containing the enable action (in the context panel customization). Thanks, that worked!
  • Cannot edit notes when objects are hidden
    @Ingolf Added this to the backlog.
  • Pen tool - Cusp nodes in smooth node mode
    @Ingolf Could not replicate this earlier. I will try again, with the new info.
  • "flip horizontally" button with option sends result way off screen
    @Boldline Well, one thing that could help is to find out what are the prerequisites for this to happen. For example: what other actions are taken before. Something preferably short that can be repeated just after starting the app and then replicates the issue. But I will also look into this from a different perspective. There is a lot of persistence happening in the VS UI and it could be that the flip change keeps some size / position from a previous flip.
  • Corner Fulcrum Bug ?
    26
    38k Views
    @b77 said in Corner Fulcrum Bug ?: @VectorStyler If the next build will have changes related to all this, please explain the changes here when it's released. Before I forget: The only change that will be in the next build is that when a free path (not parametric shape) is scaled or rotated and the "Direct Shape Transformation" is enabled (already exists), then instead of adding a "nondestructive" transform to the object, it will just scale the path, leaving the corners "rounded".
