• Unit Soup
    @Ayo said in Unit Soup: When I specify units for Type as points I want to see points (supervisory). Found the bug. The various leading, etc fields use the wrong defaults. Will be fixed.
  • Artboard stress
    @Ayo said in Artboard stress: Stack order in panel represents print/export order. That's correct, isn't it? Yes, stack order in Canvas& Artboards panel.
  • [Bug] Strange behaviour of scrolling lists
    @encart Clearly a bug, added it to the backlog.
  • Font color in text frame
    @VectorStyler OK, could be that the mockup is oversimplifying things — this background color needs to be added as content that can accept transparency masks, effects, etc, right?
  • two Buttons in layer panel are too similar
  • Was the transform panel removed?
    @Boldline said in Was the transform panel removed?: If I wanted to add it back in again at the top, would that be in the contextual menu bar or can we also alter the very top menu bar area? This can be edited with the Customize Toolboxes command and in Toolbox select the "Context Panel" mode.
  • Stable font for Typotesting
    @VectorStyler Now you beat me! I ask you an inch, and you go 3 inches. I will be coming back to this later.
  • Paste Text Bug
    @Ayo If it crashes with this again, back up the resources folder. It might be some settings causing this.
  • Split Object Shape on gradients - a bug?
    @Harry Not a bug. Currently the gradient is aligned to the object shape. I will try to improve this in the future.
    @Harry context panel restricted by design. CMYK, HSB etc. values in color panel I have to check why this happens (could be also by design to restrict accidental changes).
    @Harry Replicated on Windows. It should not show these if there are no condition variables defined, can be ignored. Will be fixed ASAP.
  • beta 1.2.003 update
    6 Votes
    @Harry said in beta 1.2.003 update: In the profile editor view, it doesn't work at all. Replicated on Windows. I will fix this ASAP. As a workaround, drag the node out of the profile area to the left or right to delete.
  • Trouble with Snapping Icons
    @Ayo cool, like them
  • Pen tool icon/pointer
    @VectorStyler this will be difficult because when I click outside the VS workspace, I get the correct icon (which may disappear but always comes back)... I mentioned this issue because I thought it was permanent but it ends up working... so, weak prority to that
  • Did the brush width indicator change? I don't see a difference
    ok maybe I'm all set - I've updated the build since then and the icon for the path brush and eraser are both the current circle with brush inside and no longer the elongated cross hairs. Maybe I need to play around with it more but the two settings do not seem as different anymore from one another. I will test it more and get back to you
  • Serif Font while font selector says Arial
    @Ayo Added this to the backlog.
  • Contour stroke: bug?
    @VectorStyler I have already forwarded the file to you previously if you want to test it
  • Artboard Label Settings
    Suggest putting the options in tabs on the right side - "Sizing", "Appearance", "Artboard Label", "Slice Label" perhaps? As long as there are only a few, logically organized tabs in a section that is still a logical and accessible way to organize these. Just need to be careful that it doesn't get out of control and lead to one of the three cardinal sins of tabbing: scrolling tabs, multiple rows of tabs or tabs within tabs.
  • after installed beta 1.2004, 1.2002 still there
    @VectorStyler The thing is that it wasn't installed in a different folder. But as always in the Vectorstyler folder. But it's not a big problem. Just wanted to report it.
  • New release - doesn't install
    Yes indeed, I had also allowed the "repair" of VectorStyler the first time not knowing what to do, and the complete installation succeeded after the fix of the beta version.
