@DMBrown said in Actual Size is larger than actual size:
5120 x 2880
Yes, this is the same as the iMac. I think there is a bug here somewhere, I will try to fix it ASAP.
@VectorStyler said in How do I set the number of digits in the Distance to three?:
Here if I set the decimal width of Inches to 3 (or 4) in settings it will display with those number of decimals in the offset path view.
This solution does work. I set it to 4 decimals and everything is better. It also improves the slider
Yes, in Windows 11,
Main display is 3840 x 2160, Scaled to "150% (Recommended)".
Second display is 2560 X 1440, Scaled to "100% (Recommended)".
@VectorStyler The first issue has been fixed in version 1.2.009, the second issue is still unresolved, as shown in the following images: correct display and incorrect display.
[image: 1705569798773-correct-display-resized.jpg]
[image: 1705569807277-incorrect-display-resized.jpg]
@Boldline said in Color panel does not auto-collapse when clicked away from:
Is this intentional or just a bug?
The iconified panels stay open, until you click on the icon again. This did not change from before.
@VectorStyler said in The issue with ungrouping after bending:
@Li-Xiao Meanwhile I fixed the issue (partially, not yet the crash). It is caused by the use of object clones.
Regular duplicated objects show work with bend ungroup.
Fixed. thanks
