    @vectoradmin Wow my mind is blown!.... I need to take some time with this! Thank you for explaining. This is awesome
  • Text rotate center by default?
    Thank you for fixing this! I will test it out more but I'm liking that it's right in the center by default now
  • License server down?
    Thanks for the fast reply! I just activated now.
  • live Warp settings do not carry over to another VS document
    I tried to replicate it again as well. I think I had copied it when it was still selected using the warp tool. When I tried again using the transform tool, it carried over the warp successfully to the new document
  • Adjusting length of rope stablizer
    @vectoradmin ok thanks - I had accidently shrunk my box some and that was obscured - my fault.
  • Sampling Colors from imported images/ artboard/background
    @Boldline It's in the name of the tool — Copy Style. Simple click with it copies the fill(s), stroke(s) AND the image effects of another object. Shift-click picks only the fills and strokes from vector objects and color from bitmaps.
    Ok.. Do what works best. I'm not a programmer. I guess what I was seeing was that the initial pieces used to make the blend were left behind after the blend was made. But I'm not saying I'm right or what I'm suggesting is best
  • How do I create a Compound path?
    @vectoradmin Thank you for explaining! This makes more sense. I had seen the combine option in the boolean operations panel but my Illustrator brain was not computing that - I get it now
  • Should "Locked" be renamed "Lock" "Hidden" be "Hide"?
    @Boldline Will do so.
  • Path Simplifier Tool same as Smooth Tool in Illustrator?
    18k Views
    @vectoradmin When you add it, it could probably go in the same place the path simplifer is now - or it could be a built in part of the path simplifier and make it a toggle or option as to how it gets used. Just my thoughts
  • Rotate View Tool Return to 100% upright
    @vectoradmin I also like the tool for rotating and getting back to the initial angle located at the bottom left of the app. Just really 'noticed" it That is helpful as well. Easy access and location
  • Thanks for small hidden tweaks
  • Pen Tool Guide Toggle
    @b77 thanks - sometimes it's hard to know where to look in the preferences. "changing options" wasn't clear enough to me to know to go there. Not that I have a better name idea lol. thanks again
  • how to clean up space at top of VS screen?
    @vectoradmin Thanks! the Shift-Option-Command ultimately solved it.
  • Paste Below place objects in between initial selection
    @encart Can be replicated! Added to the backlog as a bug.
  • Inking Process Help
    30
    61k Views
    Great! This would offer a solution the times users want to make use of the pressure option and still expand and divide those pressure based strokes. Thank you!
  • Awesome work!
    @Boldline Thanks a lot! Things are progressing normally. I decided to postpone this weeks (Mondays) release to have some much needed features added. But the release should be out later this week, or latest on Monday
  • kerning and leading
    @Boldline Leading will not help in a single line text. Kerning will only work, if there are kerning metrics defined in the font, and those are then scaled up/down. To uniformly adjust distance between character, you need to use Tracking, that is set in the field with the Ta icon (just under the kerning label).
  • snap handles into nodes status
    @vectoradmin and @Boldline As I said, I would like box selection to work also for multiple handles, but it would be a problem if 'Select Nodes from All Objects' is not disabled in Prefs > Editing Options. What would be an elegant solution? /\/\/\/\/\/\/\/\/\/\/\ EDIT: What if the app would restrict the nodes and handles that can be selected to the selected object(s) by default, and only if nothing is selected allow the selection of nodes & handles from all objects? This as the default selection rule when in node editing mode would make more sense to me at least, solve the problem above and generally simplify things (probably make the 'Select Nodes from All Objects' prefs setting redundant).
  • Questions about rotating an object with two different centers
    @861475_VctSt (d) is a bug.
