@monsterfox I added these to the backlog (1) and (3).
The problem for (2): all images are clipped (in a rectangle initially, but clipped), this clipping "frame" can be styled with fill and stroke, just like any other object.
@VectorStyler Thank you. It's an important function for things like lettering/logotype. An easy example, if someone is designing a custom typeface that's based on a skew, having a snapping feature would speed things up for getting those clean curves...
Ah, I confused "Convert to Shape Text" with "Convert Frame Text to Path". Thanks!
[image: 1741712885586-38216545-7162-4799-9ba7-e4817a1068ec-image.png]
@VectorStyler https://youtu.be/gOM3Fp3GIW0?feature=shared
This video should be understandable. Hiding and showing will not be counted as part of the operation steps.
@VectorStyler thanks! I figured out if I turn off the symmetric nodes and the "show segment" options, I get the pen tool settings that work best for me.
With your Command+ option, I see it can give me pure cusp nodes when using the pen tool. that can be useful
[image: 1741187704496-270a437d-9824-44b9-b04c-cd1d6e78f3d0-cleanshot-2025-03-05-at-10.14.35.png]
@fdarnel said in Opened windows:
I had created a group Layers/Canvas/Links. The 3 then disappeared after restarting. It doesn't happen everytime.
I will try to replicate this.
