      Distinguish keyboards
      • monsterfox
      8824
      @monsterfox said in Distinguish keyboards: The shortcuts for the main and numeric keypads are not separated. I will try to find a solution for this.
    • Non-destructiveness vs new (visible) reality
      • Ayo
      12060
      @Subpath I am not specifically concerned with more or less functionality, but with the difference in behavior with the same functionality.
    • Changing the UI font in the settings isn't reflecting - What am I missing?
      • Daniel
      2263
      @Daniel There seems to be an issue on Windows with this. I opened a bug.
      About images
      • monsterfox
      1902
      @monsterfox I added these to the backlog (1) and (3). The problem for (2): all images are clipped (in a rectangle initially, but clipped), this clipping "frame" can be styled with fill and stroke, just like any other object.
      Expanding fill patterns
      • Fertuffo
      2282
      Thank you so much
    • How to snap handle to the tangent line?
      • Ayo
      7698
      @VectorStyler Thank you. It's an important function for things like lettering/logotype. An easy example, if someone is designing a custom typeface that's based on a skew, having a snapping feature would speed things up for getting those clean curves...
    • Bending and Arching editable text objects fails
      2542
      @VectorStyler Ah, I confused "Convert to Shape Text" with "Convert Frame Text to Path". Thanks!
    • Shape Effects, vector handles unresponsive
      3404
      @VectorStyler Ok, makes sens
      Feature repair
      • monsterfox
      1764
      @monsterfox I added this to the backlog.
    • How to change parameters by scrolling in the text boxes?
      • Daniel
      3351
      @Daniel This behaviour works in panels and views, but not in the context panel (upper row).
      Apple mouse wheel use
      • fdarnel
      2412
      Thanks!!! It seems you also have to restart VS.
      About Hiding
      • monsterfox
      3484
      @VectorStyler https://youtu.be/gOM3Fp3GIW0?feature=shared This video should be understandable. Hiding and showing will not be counted as part of the operation steps.
      Snap to points
      • monsterfox
      1863
      @monsterfox I added this to the features list for later.
    • Where is the option in context bar to change default pen tool mode?
      2528
      @VectorStyler thanks! I figured out if I turn off the symmetric nodes and the "show segment" options, I get the pen tool settings that work best for me. With your Command+ option, I see it can give me pure cusp nodes when using the pen tool. that can be useful
      The square tool has no control points.
      • monsterfox
      1830
      @monsterfox To resize a rectangle without distorting the corners, enable the Settings -> Editing -< Direct Shape Transformation option.
      Opened windows
      • fdarnel
      5200
      @fdarnel said in Opened windows: I had created a group Layers/Canvas/Links. The 3 then disappeared after restarting. It doesn't happen everytime. I will try to replicate this.
      Importing PDF, maintaining layer structure
      • Pipouille
      6749
      @Pipouille I correct myself: the names are in the PDF metadata. In the next VS build these will be used.
    • How do I unlock a specific vector or vector group without unlocking all layers?
      1762
      Update - I realized I could just go to the layer and select the individual parts there... in my head I was looking for a layer-level option to do this from the menus I showed in the screen shots.
      How to just add a node on a curve very accuratly, using magnetism of curve and guides?
      • fdarnel
      7193
      Thanks for the workarounds. I'll try them.
      It is possible to get rid of the blue selection frame around Objects ?
      2489
      @VectorStyler Works great, thank you
