  • JPEG XL support
    @nocturnalYL I have this in the 1.3 backlog, I will try to implement it, subject to the availability of suitably licensed implementation.
  • Extend Windows menu buttons hotspot to the top
    @nocturnalYL I will try to improve this.
  • NEW UI
    @fde101 Everyone's work habits and the program interfaces they use are different. It's fine to find what suits you. You should be used to the interface of Illustrator software, while I'm used to the interfaces of FreeHand and CorelDRAW. I have been using them for more than ten years. It's very difficult to change this habit.
  • Consolidating smooth and symmetric options in a dropdown
    @Boldline I will try to find a solution for this.
  • Opening of Layer Menu Panel Auto Highlights Name
    @Boldline The name field supposed to be active after opening, but I think the highlight is not set by default. I added this to the backlog.
  • Alternative method to save recovery files?
    @Boldline There seems to be a regression here. The problem was identified and the fix will be in the next build.
  • ornamental stars
    @VectorStyler yes you are correct. I was expanding on the idea by sharing a few different stars that this could work with and could potentially be included, not just the standard five point star. No rush on my part to add these. I was just using them today in my work and it reminded me to share
  • Perfect symmetrical dotted lines
    @monsterfox I added this feature to the backlog for 1.3
  • Data Source for Artboard Naming
    @encart Data sources documentation is here: https://www.vectorstyler.com/documentation/symbols/datasources/ Related to this are number variables: https://www.vectorstyler.com/documentation/symbols/numbers/
  • Small Improvement to Panel Snapping
    @debraspicher I added this to the backlog.
  • Menu focus should follow cursor
    @debraspicher I will try to modify this.
  • Polar Grid Tool
    For VS, I was thinking more of a "concentric grid" parametric shape option to get a "polar grid/radar" type of graph
  • Affinity Designer import
    7 Votes
    No, it's probably not simple, but perhaps this project could be of some help. I'm sure they've reverse-engineered it. I hope you can find a good lead. It's precisely a format shared by all three applications, so I hope the vectors are reasonably separate and identifiable. My big curiosity is whether it's a spaghetti formatβ€”or if it's well-designed.
  • Regarding the halftone repeater types
    76
    205k Views
    @VectorStyler Sorry, I've been a bit busy lately. I didn't explain clearly. I meant multiple blended shapes, not a single blended shape. I couldn't find the files I make on before. I'll redo them when I have some time and send them to you.
  • Help with Path Brush Tool
    @VectorStyler: Thanks a lot!
  • ruler editing
    @ZATOPEK This is in the backlog for 1.3 (later)
  • Thoughts on the Distortion Tools
    @VectorStyler said in Thoughts on the Distortion Tools: @Subpath I added this to the features backlog, and I will try to find a solution for 1.3 some distortion Tools into one Tool This last point is not clear Let's say you have 4 distortion tools that are most similar, e.g. in terms of settings. That these could perhaps be combined into one tool and the options of the 4 tools could then be accessed via a dropdown menu in this combined tool. This could reduce the number of distortion tools somewhat but keep the features of it. Just an Idea dont know if this makes sense.
  • Pucker tool like functionality.
    @Subpath @VectorStyler Thank you very much for the help. Needed this function for a project work. I can use both the circular and liquify brush settings shared here. I agree illustrator tools are very fluid over VS brushes, may to find the right settings and speed as you pointed out.
