  • Sharing work for inspiration and learning
    @richbyte We can use the Tutorials category for this.
  • Bucket Fill Shape Creation
    @Boldline A Shape Paint Group can be expanded using Styles -> Shape Paint -> Expand Shape Paint.
    I agree that it will be hard to find a happy medium with such a variety of uses. Personally, I like the Move window style called by the Enter key When the object/group is selected, you press the key that activates the window, you can move around with the Tab key. That's how I see it First press Enter a Transform window with typical properties appears there should not be many of parameters so that moving between them without using the mouse would be fast and efficient. 9-Point Reference Object Origin - also possible to highlight with the Tab. Points can be selected with the 1-9 buttons Second press Enter The Move window appears Press Enter for the third time The Move window disappears I think it would be a relatively intuitive and practical system that quickly becomes a habit.
    @Vector-Rock I added to the backlog a dash/cap selection improvement task.
  • Is the size of the text used on the forum OK for everybody?
    forum
    @Boldline Will try to fix the VS link. Lets have more input on the font size.
  • Scrolling the contextual panel bar
    @vectoradmin Thank you for always answering my requests. It's always fun to see how it gets easier and easier to use. There are 24 commands in "combine" alone, so I have them all hidden for now. I've hidden all of them and right-click on them to call them up. However, it would be nice to have an icon.
  • App Icon, still strangely blurry
    17k Views
    @b77 @vectoradmin Not sure what happened and why your first screenshot was different. The following resources I uploaded in my first post may not be for Mac. In particular, the ".ico" extension is for Win. /Applications/VectorStyler.app/Contents/vector/data/resources/appicon.png /Applications/VectorStyler.app/Contents/vector/data/resources/appicon.ico I found ".ics" in another directory. This seems to be the resource for Mac. /Applications/VectorStyler.app/Contents/Resources/AppIcon.icns There are 10 images in "AppIcon.icns". I exported the 144DPI, 1024x1024 image from this one. (fig) [image: 1628486588046-an_icon-resized.png] Anyway, can you confirm you downloaded and tested with the .icns file I sent via forum chat? I DL'd it from Dropbox. This is a VS resource. This is the same as your image. The difference is that yours is a screenshot image (1012x1047). Mine is a resource image. Improvement Case Below 72DPI 128x128, false colors occur in relation to the background. Two suggestions for improvement are as follows Make the blur of the corner R frame a solid color stroke. Eliminate the dot pattern.
  • Add a Document Palette
    @b77 @Vector-Rock I will check if we could have such popup menu. Having a list of recent fill styles somewhere is a great idea, I will add this as a feature request to the backlog.
  • Add Edit Fill and Outline Options Dialog Boxes
    @Boldline Yes I agree that over time, as VS continues to evolve and improve with each update , as VS Documentation is further developed, and as more people become knowledgeable about the program and post videos and other tutorials, it will help us all get a better handle on the program. All vector programs have a steep learning curve to a beginner. The developer has acknowledged VS has a steep learning curve. It goes hand-in-hand when you have a program packed with a lot of stuff and still in early development. I mentioned it in the context that anything (like improving the Status Bar) that helps people grasp the program sooner in today's "microwave society" (not saying I agree with it, but just how it is), will help VS succeed (and I know you and I are amoung the biggest contributors and champions of VS! ) While of course the target market is relevant, the focus and goal should be to make the program as simple, intuitive, and user friendly as possible, regardless of the experience of the user. Even power-users don't want stuff harder to use just because they have experience or can figure it out, ha, ha: It is encouraging to see the continued improvement of VS. The developer and its loyal users need to continue to press forward to help continue this trend.
  • Enhanced Color Palette Options: Color Values, Tints, Drag and Drop
    @Vector-Rock These exist partially: Name or RGB values are shown Drag&drop over non-selected objects applies as fill I will add these to the backlog as improvements of existing features.
  • Document Default Object Properties Options
    @Vector-Rock I add these to the backlog. Technically these will be doable, once the status bar is implemented.
    @Vector-Rock I will add this to the backlog for new features.
  • Adding a Choice within an Action set and other ideas
    @Boldline I think these are all doable. There is a plan to improve the way actions are handled, once the (public) plugin and scripting is available (around version 2). I will add these ideas to the backlog, but they will be implemented further down the road.
  • Pencil tool improvement?
    @vectoradmin said in Pencil tool improvement?: BTW: if there are some specific features of FreeHand that would be good to have, please just post about it. Thanks. I will. I think I keep the Freehand manual downloaded not so long ago. https://www.manualslib.com/download/389871/Macromedia-Freehand-Mx-11.html
  • Intro 3d
    @STEVED Is it possible to import SVG into Blender? VectorStyler can export to SVG. Extrude, is in the requested features backlog, and will be implemented some time, but probably around version 2 only.
  • Dealing with colors
    27
    53k Views
    Yes, thank you.
  • Improve the Line Drawing Tool with Dialog Box Options
  • Mirrored guideline when rotating objects
    @b77 @vectoradmin thank you both - I'll experiment further. Really enjoying VS - so many ways to use it
  • VectorStyler Needs a Website Revamp!
    @richbyte I agree, at some point soon it has to be reworked.
