  • Reprofile Tool
    @Subpath said in Reprofile Tool: is there any way to keep the original Path apart from copy it ? The original is shown only while editing. Once you exit the tool, the results are "flattened". And are multiple Offsets possible ? You mean "new offsets"? Yes, you close the tool and select it again, then you can add offset to another part of the path.
  • Support for Industry Standard Color Profiles
    @JuurGroove said in Support for Industry Standard Color Profiles: /System/Library/ColorSync/Profiles ~/Library/ColorSync/Profiles The content of these folders might be managed by MacOS. In this case, it is better to have these profiles in some user folder, and point VS to that.
    @Boldline I will try to implement this.
  • Group replacement
    @monsterfox I added this to the features list.
  • VS still does not support this operation.
    @monsterfox Yes, but in VS you can paint over the regions to be united into a shape. I will try to add this box selection mode also (but for 1.3 only)
  • Option to quickly flip a gradient color order in gradient panel
    @Li-Xiao Oh! I had to open the panel further with the double click at the top. thank you
  • "-" (minus) key to delete nodes inserted with the "+" key ?
    @VectorStyler i know i can delete using the Delete key but only for newly inserted Nodes i was talking about reverse these Steps (delete the Nodes) in the direction there was inserted Here a video about it . . But I would say forget about this suggestion for now, this may be perhaps a too special case It is a bit more complicated but in the end you can select the nodes you want to delete.
  • Talking about popup windows...
    @Ayo I opened a bug on this. The drop shadow is controller by MacOS, but I think it can be disabled.
  • Inverted wave, zig zag, with the "Outline Zigzag" shape effect
    @VectorStyler thank you I have already tried "shift" on open paths, but that didn't work, so it only works on closed paths. The interwine effect of the 3rd image, the circle, is not needed. That was just an example of what would be possible. I created it with the shape builder forgot to mention it
  • text color indicator
    @VectorStyler Thanks. ver. 1.2.052. The charactor palete now has a slider bar to set the opacity of the text color.
  • Panel Input Considerations
    @VectorStyler The criticism was that it wasn't deactivating the field input together when clicking away from that panel, not that it didn't have that outcome (edit: Though I can see why that's unclear). It should ideally do that when clicking off somewhere in VS and it shouldn't be reactivated for input when moving back to that specific panel. But looking at the video, it could be a matter of an extended click zone for the type size field in particular in the Character Panel. I clicked in between the word Leading and Kerning (in-between those field labels) and it reactivated the type size area just now in testing... Other areas of the interface are like this that when looking for dead space to focus panels or dialogs, it reactivates areas for input. It creates friction because it often is a habit with many users to either Escape or close out input by clicking white space in panels, etc. Edit: In most cases (if not all), it's usually input fields that take keyboard entry, aka text, that causes the most slowdown in this way.
  • Option to auto-scale live text to same height or width easily
    @VectorStyler thanks for showing me!
  • Shortcuts for color manipulation
    @861475_VctSt said in Shortcuts for color manipulation: they work on fill even when stroke is selected. I will try to improve this.
  • Move "Show Grid Margins" to global?
    @Ayo I added this to the backlog.
  • Resetting the Rotation and Skew commands
    @hbalcic I will try to find a solution for this. Meanwhile, use the Angle value in the Transform panel.
  • Arrange - Reverse Z-Order
    @hbalcic Can be customized with Customize Toolboxes and selecting "Context Panel" in the Toolbox drop down.
  • Dragging Panels
    @4f00d I added this to the backlog.
  • Option to rearrange Artboards
    @monsterfox The Canvas -> Create Artboard command can add multiple artboards in one step.
  • Ideas for updating the color replacement panel further
    @Boldline I added this tot eh features backlog.
  • Path Length option in Contextual Menu hard to control
    @Boldline said in Path Length option in Contextual Menu hard to control: Could it favor a lower range of sizes? I will change this.
