    @Boldline Currently the font is not included in the attribute copying. I added this to the feature backlog.
  • Expand the color choosing options for the Bucket Fill Tool
    @Boldline said in Expand the color choosing options for the Bucket Fill Tool: So unless I am missing a step, I am unable to preemptively choose the color I want the selected shape to be filled with. I think that changing the color will work after the first bucket fill click. The problem is indeed that selecting the objects will update the current color. I will try to improve this.
  • Regarding the selection-related features
    @VectorStyler Thanks. There are two areas for improvement: allowing multiple selections in the preset list overlay and enabling the selected nodes to save presets. https://go.screenpal.com/watch/cZhllAVLiIa
  • Artboard printing / exporting in the order set by the user.
    @Harry Not for the export tool, only for printing. I will try to add it for export also.
  • Webpage Font Hard to Read
    @Teddy Keep critiquing because it will help the development of the UI/UX aspect of the program. Some aspects of application design is subjective to the general user, but with more input across the board, hopefully it becomes a lot clearer to the developer the best path to take for VS.
  • new tool
    @monsterfox Got it. I will add this to the feature lists for 1.3
  • Blend Tool needs Split function
    Great, thanks for the input @Li-Xiao and for the effort @VectorStyler !
  • About half-tone
    @VectorStyler Look forward to a stronger VS.
  • Quick Adjustment of Swatches
    @debraspicher So this would be some sort of ""Palette Editor" view. Yes I think it is possible.
  • Multiple shortcut keys
    @monsterfox Sorry, I gave the wrong example (the number keys are fixed). So first remove the "S" shortcut (assigned to the Pattern tool), and then create for example "S X" for some tool and "S Y" for another tool. This should work.
  • New selection mode
    @Li-Xiao Thank you.I'll try it later.
    @Boldline I added this tot he backlog.
  • Create an action based on history
    @Subpath said in Create an action based on history: @Pat ... Because you can design without having a Script Recorder in Mind. That's exactly what I thought : we're "starting new adventures" with VS , we're enjoying the design and we'd like to record all steps quickly and easily. Two steps would be perfect: recording an action from the History panel and importing it from the Action panel ...
  • Integrated menu
    @Subpath You have a great plan, too. Thank you for your help.
  • Pen tool - fill shapes usability
    @VectorStyler said in Pen tool - fill shapes usability: @Ingolf said in Pen tool - fill shapes usability: I will try to find a solution for this. The context panel is a bit loaded for the pencil tool (npt much room left). This setting also applies to the pen tool, which is what I use the most and mentioned above, but in the settings, it says pencil tool, so it's extra difficult to guess what the setting covers. Yes, there's a lot going on in the interface, but perhaps you should consider using text labels less; they take up a lot of space and, of course, are easier to understand, but visually, they take up the equivalent of 4-5 small icons, and I think they create a cluttered interface. But anyway, I referred to the setting in the pen tool, but I would say the issue also applies to the use of the pencil tool. Cheers
  • Shortcut option to close shape when arc tool gets added
  • Layer panel customization after 1.2 changes
    C
    In any case, I find the color coding too wide, Illustrator has very nice narrow stripes.
  • Saving indicator color
    C
    @Boldline said in Saving indicator color: I'm not saying it needs to stay purple, but I do like that it's a subtle change that does not distract from my work, yet it is noticeable as it changes. Maybe if it went to orange then red? Purple is a very difficult color: In the dark UI you notice it too late and when you notice it, it disturbs your design colours no matter what color. Orange and red are too similar. The classic sigal colors are green, yellow, red. Maybe a slightly muted yellow, like R255/G255/B150 or just red?
  • Option to save imported file directly to same folder and same file format
    @fde101 said in Option to save imported file directly to same folder and same file format: What it is actually doing is importing the PSD but remembering where it came from and what it is, and when you "save" the document, it replaces the original PSD with a newly exported copy instead Yes, but it will lead to loss of information. I will find a solution for this.
  • Please add a 'search next' in the Customize windows
    Thanks all. I think these arrow-buttons are more obvious and intuitive and I agree that it's best to keep UI consistent. Nice to see this added, because this is one of those hidden features that are easy to forget, let alone for newcomers.
