  • Appearance Groups and Repeaters?
    @fde101 I will try to find a way to do this. Certainly not through the Shape Effect panel, as those can alter shapes only (not styles).
  • Creating Shape Paint artwork using the Shape Paint Tool
    @VectorStyler said in Creating Shape Paint artwork using the Shape Paint Tool: @William-Kansepa We could create the Shape Paint object at the first click, from the selected objects. Would this be suitable? Yes, that is exactly what I meant. Thank you.
  • Idea for functionality of a built-in note text file in VS
    @Boldline I added this to the features backlog.
  • My mini wishlist
    @William-Kansepa said in My mini wishlist: list item.tif file format export. At present VS only has the .tiff option. Although not highlighted in the release notes, this issue has been addressed in VS 1.2.027. I can now export *.tif in VectorStyler. Thank you @VectorStyler!
    @Boldline The "Separate Offset" refers to the object selection, do we apply the offset separately on each or on the whole as a single object. The "Combining" option refers how to treat the one object (and the combined object if separate is not checked). Not sure yet if these two could be merged into a single option.
  • Can Pasted Live text be added to the "Recent Fonts" automatically?
  • Disturb colors?
    @Ingolf I added this to the backlog.
  • About the action panel
    @VectorStyler You are very powerful and worthy of admiration.
  • Consolidate the Color Panels under the Panels menu?
    @VectorStyler said in Consolidate the Color Panels under the Panels menu?: @Boldline Would it be under a sub-menu? Cannot make a single panel out of these, as it would create confusion. Correct, I was implying they would be under a sub-menu. I should have elaborated further. I was envisioning the color choices in a sub menu similar to how some others in the Panels menu are set up, like "Text" is currently [image: 1716991122555-36eec787-4a7e-4d02-88a7-77fc50bb8156-bld-2024-05-29-at-09.57.43.png]
  • Smart ways of image replacing
    @VectorStyler said in Smart ways of image replacing: What if in case of a single file import, and if a single image object is selected, the Place tool is not activated, but the image is replaced? I used to prefer this earlier behaviour in VS, but it has since been changed...
  • Add a direct link to the backup file location in the help menu?
    @VectorStyler Thank you. I was giving this a little more thought. To me, it would also make sense if the settings preset file was also available for direct link. I don't know if the best place for that is in the help menu because the user is more likely to have their own separate custom location for custom settings presets, maybe an option in the settings panel with a direct link to where the file is stored? [image: 1716904218981-df33567b-fa1a-4c91-a259-7ddabc914577-cleanshot-2024-05-28-at-09.47.40.png] [image: 1716904887672-93987ac0-e2cf-485b-92ed-99efbc81d4f1-cleanshot-2024-05-28-at-10.00.51-resized.png]
  • A better way of aligning Shape/Point Text
    @William-Kansepa said in A better way of aligning Shape/Point Text: e.g. Align Left to Align Centre, the text shifts and does not maintain x coordinate. The problem is that in VS (as in AI) the text is aligned relative to a text position. This is not possible to change for now, but I will try to find a way to automatically "move" the text when alignment is changed (in some cases).
  • Changing units by typing its symbol
    Thank you! Works great.
  • Saving node selection
    @VectorStyler said in Saving node selection: But the Selection saving for nodes it seems to not work (with the (+) button). I will fix this. @VectorStyler I can confirm that this is now functioning as expected in VS 1.2.0.25. Thank you.
  • "Show Center Mark" option in artboard options?
    @Boldline Yes, this is in the features backlog.
  • The emergence of the tool attribute
    @VectorStyler The main thing is that the tool attribute bar appears once by clicking in the document, which is quite annoying, and this needs to be eliminated.
  • VS clipboard being overwhelmed
    @William-Kansepa I will try to replicate this.
  • use a point to lead the whole
    @monsterfox There is no such feature now. Not clear how this would work. What happens if the blue nodes on the left (36) are moved or the line is changed to a curve?
    @William-Kansepa Thanks for explaining your thoughts on this. I agree with you completely. There are several examples like this in VS where the main task itself is a little more complex than it needs to be. VS has so many extra cool features that I don't want to compromise those either. I was asking you for more elaboration because we can all watch the video and pick up different things we like/dislike about the process being demonstrated. There's a value in articulating our own view and adding that to the conversation for improvement. I appreciate what you shared.
  • Curvature tool as a modifier key option to the existing pen tool
    @VectorStyler Thank you! this will be an awesome improvement. At the risk of beating a dead horse, I would prefer it to NOT be a new tool in and of itself because I think it would be something a user would need occasionally, but not enough to go switch to a dedicated tool to do so. Hence why I was thinking a modifier key option while using the pen tool would suffice. Just my opinion. You would know best what fits the VS scheme!
