  • Flip dimensions quick option in the artboard panel?
    @VectorStyler said in Flip dimensions quick option in the artboard panel?: There is the Landscape checkbox that should do a similar thing. True. I guess I was conditioned to look for the swap icon. It can stay as it is if you prefer the "lanscape" checkbox
    @Boldline Got it!
  • Reduce less used options on menu bar to a single icon with dropdown
    @Boldline yes, I also like that you have virtually independent groups of functions that you can switch on and off as needed. Or you can put them together as needed.
    122k Views
    @b77 said in Remove selection info from the toolbar please - can be seen in the status bar: (Btw, do you need to use the 125% UI scaling with that low screen resolution? Is it something commonly done on Windows?). I tried the 100% but than it's unreadable on my 14 inch screen. And yes with smaller screens Windows recommends even greater UI scaling.
  • Add dropdown option to show remainder of boolean operations?
    @b77 said in Add dropdown option to show remainder of boolean operations?: Also: I use 'Exclude Last' a lot — I would prefer it available directly. Interesting. Seems like there are a number of them that "everyone" uses and then other "lesser used" ones that each of us use with greater frequency
  • Easy flip option for height and width
  • Multi purpose use of shortkeys
    @VectorStyler When clicking the letter B you get first the Brush tool and when pressing again you get the Crop tool. You get the same sort of cycle as with returning to the previous tool. Only now it is applied to only the tools with the letter assigned. So the function of returning is for the multipurpose assign keys disabled to go back to the previous tool. And when you go back to only one purpose assigned key the returning to previous tool is enabled again.
  • Idea related to the Panel width
    @Subpath I added this to the backlog
  • Working with panels
    @FastVector Thanks for the feedback. I thing (1) and (3) are doable. (2) is a bit problematic, because horizontal panels cannot be stacked into a tabbed view, so the whole moving thing is going to be different.
  • Reference Scaling
    @Ayo I added these transform improvements to the backlog.
  • Preview option for shape tools
    @Kumr Should be possible to add. There is also the Shape panel that contains a bit more options than the context panel. I added this to the backlog.
  • Standard paragraph presets
    @VectorStyler The idea is to help on boarders and for someone would like to do a quick mockup work. Some basic styles, presets, etc, which ever possible so one can kick start their work for eg, the bullet list in the above screenshot.
  • Misleading
    @VectorStyler said in Misleading: The main issue that the "dual" character / paragraph leading thing will stay in some form. Why? As long as it's invisible, it's ok for me
  • Preview Text Frame indicator in Node Tool mode
    @Ayo Thanks for reporting this. It is added to the backlog.
  • Block Shadow effect tool
    @VectorStyler Got the email. Thanks.
  • Alternatives for 'drawing place' icons
    @Harry Thank you. You're right, that association also occurred to me. Now I have placed the pencil a little further away (as far as possible because space is limited in a square) and more away from pointing towards the center of the circle. Think that's better. Send an update of the file to Vectorstyler. [image: 1699610509871-4834800c-2c6a-4c80-9a49-26c37aef0524-image-resized.png]
  • "Paste and Match Style" feature
    @Ayo Send me the file where this occurred. Could be there are are some other issues with the text (related with the earlier comment on pasting formatted text).
  • Select All Objects while working in the Node Tool
    26
    38k Views
    @Ayo Sometimes there are different paths to reach the destination. I just chose an additional route. As long as we reach the destination, wouldn't it be better if there's a faster method? For me, I prefer having multiple ways to achieve the same goal. In case one method encounters a bug, I can switch to another method. This is the best approach before the bug is fixed. Of course, everyone has their own way, as long as the goal is achieved. Thank you for your many suggestions. They will make VS even better.
  • Two alternatives for Break Shape
    @Ayo Added this to the backlog.
  • Option: Snap to point/shape text
    @Ayo Background Example usage. Point Text is an ideal text form to use in cartography. Compact and bendable too! In a typographic layer with a high density of text objects, you want to use text objects as snapable, but not the text (glyph shapes) itself. It is insecure in aligning symbols to text lines (no need to align to acender, x-height, O-height etc.) and also saves a lot of visual clutter caused by flickering indicators. [image: 1698586470222-7508690e-0572-46ae-b78d-a93cf1bf63c3-image.png]
